AzureAD SAML AppRole setting
  • April 4, 2022
  • 141 views
I have implemented AzureAD and SAML settings with reference to this page, but when I log in to Automox as User Role, it becomes Read Only.
Reference URL: https://support.automox.com/help/azure-ad-saml-support
I would like to add the Global Administrator role to AzureAD.
The value in the AzureAD manifest does not allow the use of spaces and
I cannot grant Global Administrator privileges.
What is the best way to resolve this?
Translated with www.DeepL.com/Translator (free version)
  • April 4, 2022
I think we should get you a support ticket started for this, as I don’t have access to your console. If you haven’t already done so, I can forward this over to them to get a ticket started.
  • April 4, 2022
Thank you.
I'll try contacting support.
  • April 11, 2022
Support responded.
The user is created on the automox side at the first login from AzureAD, but it is Read Only.
After that, it seems that it is necessary to grant privileges to the user created by a user with administrative privileges.
It was not possible to guess the role from AzureAD user and group assignments
