Worklet to Uninstall KB5000802 & KB5000808 Causing Print/Blue Screen Issue
  • March 11, 2021
  • 2 replies
  • 143 views
Tony-Automox
As of right now, here’s the current issue: When users of Kyocera, Ricoh, Zebra printers (among others) attempt to print, they are instead presented with an irritating Blue Screen of Death (BSOD).
https://hothardware.com/news/this-windows-10-update-is-causing-bsod-crashes-simply-by-printing
If you wish to remove these from your environment, and keep them out:
First, go to the Automox software page, search for each KB, then click on the Actions button and choose Ignore for each result. This should keep them from getting re-installed again.
Second, run this worklet on them.
Evaluation:
# Look for the following KBs.  If found, Exit 1 remediate
$UpdateArray = @('KB5000802','KB5000808')
foreach ($UpdateVersion in $UpdateArray) {
    $SearchUpdates = Get-HotFix -Id "$UpdateVersion" -ErrorAction SilentlyContinue
    if ($SearchUpdates) {
        Exit 1
# KBs not found
Exit 0
Remediation:
# "19041.867.1.8" = KB5000802
# "18362.1440.1.7" = KB5000808
$UpdateArray = @("19041.867.1.8", "18362.1440.1.7")
    $SearchUpdates = dism /online /get-packages | findstr "Package_for" | findstr "$UpdateVersion"
        $update = $SearchUpdates.split(":")[1].replace(" ", "")
        write-host ("Update found: " + $update + "; ")
        dism /Online /Remove-Package /PackageName:$update /quiet /norestart
    } else {
        write-host ("Update " + $UpdateVersion + " not found.")
  • March 11, 2021
Is there a way to add in the Automox reboot notification to this?
Tony-Automox
  • March 11, 2021
You could probably just add the remediation from worklet:
to the bottom of the remediation of this worklet.
