I have installed all available patches in Automox, but the vulnerabilities I scanned on Lansweeper have not decreased. Why is this?
@jeff.luo did you run fresh Lansweeper scan after all applying all patches!!
Jeff, Maulik is correct here. Post updates, were you able to rerun scan in Lansweeper and in Automox?
For example, I reviewed the device on the backend and did not see any OpenSSH packages needed; all completed. Also, the device does not claim to need a restart; it appears that it was performed.
The software is supported by us to update - let us know if you’re seeing something different!
Hi [removed by moderator] ,
It is possible the repos configured on this endpoint do not contain the latest updates for the products in question. Can you provide the repo info here and we can assess?
My repos:
cat rocky.repo
# rocky.repo
# The mirrorlist system uses the connecting IP address of the client and the
# update status of each mirror to pick current mirrors that are geographically
# close to the client.  You should use this for Rocky updates unless you are
# manually picking other mirrors.
# If the mirrorlist does not work for you, you can try the commented out
# baseurl line instead.
[baseos]
name=Rocky Linux $releasever - BaseOS
mirrorlist=https://mirrors.rockylinux.org/mirrorlist?arch=$basearch&repo=BaseOS-        $releasever$rltype
#baseurl=http://dl.rockylinux.org/$contentdir/$releasever/BaseOS/$basearch/os/
gpgcheck=1
enabled=1
countme=1
metadata_expire=6h
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-Rocky-9
[baseos-debuginfo]
name=Rocky Linux $releasever - BaseOS - Debug
mirrorlist=https://mirrors.rockylinux.org/mirrorlist?arch=$basearch&repo=BaseOS-        $releasever-debug$rltype
#baseurl=http://dl.rockylinux.org/$contentdir/$releasever/BaseOS/$basearch/debug        /tree/
gpgcheck=1
enabled=0
metadata_expire=6h
[baseos-source]
name=Rocky Linux $releasever - BaseOS - Source
mirrorlist=https://mirrors.rockylinux.org/mirrorlist?arch=source&repo=BaseOS-$re        leasever-source$rltype
#baseurl=http://dl.rockylinux.org/$contentdir/$releasever/BaseOS/source/tree/
gpgcheck=1
enabled=0
metadata_expire=6h
[appstream]
name=Rocky Linux $releasever - AppStream
mirrorlist=https://mirrors.rockylinux.org/mirrorlist?arch=$basearch&repo=AppStre        am-$releasever$rltype
#baseurl=http://dl.rockylinux.org/$contentdir/$releasever/AppStream/$basearch/os        /
gpgcheck=1
enabled=1
countme=1
metadata_expire=6h
[appstream-debuginfo]
name=Rocky Linux $releasever - AppStream - Debug
mirrorlist=https://mirrors.rockylinux.org/mirrorlist?arch=$basearch&repo=AppStre        am-$releasever-debug$rltype
#baseurl=http://dl.rockylinux.org/$contentdir/$releasever/AppStream/$basearch/de        bug/tree/
gpgcheck=1
enabled=0
metadata_expire=6h
[appstream-source]
name=Rocky Linux $releasever - AppStream - Source
mirrorlist=https://mirrors.rockylinux.org/mirrorlist?arch=source&repo=AppStream-        $releasever-source$rltype
#baseurl=http://dl.rockylinux.org/$contentdir/$releasever/AppStream/source/tree/
gpgcheck=1
enabled=0
metadata_expire=6h
[crb]
name=Rocky Linux $releasever - CRB
mirrorlist=https://mirrors.rockylinux.org/mirrorlist?arch=$basearch&repo=CRB-$re        leasever$rltype
#baseurl=http://dl.rockylinux.org/$contentdir/$releasever/CRB/$basearch/os/
gpgcheck=1
enabled=0
countme=1
metadata_expire=6h
[crb-debuginfo]
name=Rocky Linux $releasever - CRB - Debug
mirrorlist=https://mirrors.rockylinux.org/mirrorlist?arch=$basearch&repo=CRB-$re        leasever-debug$rltype
#baseurl=http://dl.rockylinux.org/$contentdir/$releasever/CRB/$basearch/debug/tr        ee/
gpgcheck=1
enabled=0
metadata_expire=6h
[crb-source]
name=Rocky Linux $releasever - CRB - Source
mirrorlist=https://mirrors.rockylinux.org/mirrorlist?arch=source&repo=CRB-$relea        sever-source$rltype
#baseurl=http://dl.rockylinux.org/$contentdir/$releasever/CRB/source/tree/
gpgcheck=1
enabled=0
metadata_expire=6h
I have rescaned in Lansweeper.
I had rescaned in Lansweeper.
