Answer
SentinelOne installation is not 100% automated.
  • October 16, 2024
  • 983 views
Hi everyone.
Currently I've been able to install SentinelOne via script on MacOS Monterey, the problem is that some permissions still depend on manual user actions.
Is there a way to make this step via script as well?
Thanks.
Missing Permissions Permissions Required: The Agent is requires macOS Notification permissions. Authorize to allow full agent functionality.
Missing Permissions Permissions Required: The Agent helper requires Full-Disk-Access permissions. Authorize to allow full Agent functionality.
Best answer by jack.smith
@Rafaelmspc you are on the right track. Automox is not an Mobile Device Management solution. It does have the ability to run patching policies and scripts really well though.
jack.smith
Forum|alt.badge.img+1
  • All Star
  • October 16, 2024
@Rafaelmspc you need to deploy those settings with an MDM tool. Look at SentinelOnes documentation they should have an example of how to do this with JAMF which can be replicated in most any MDM solution.
  • October 16, 2024
Thank you @jack.smith .
I saw that I have to create a TCC profile and register the mdm correctly in my apple business corporate account.
Doesn't Automox support this kind of integration as an MDM?
jack.smith
  • All Star
  • Answer
  • October 16, 2024
