Solved
No override file found. Patch default values will be used
CallmePH
Having some errors pop up on a handful of pc’s when using the Patch Now Action on the Software page. Have a handful needing 23H2, and while some took the update with 0 issues some are throwing the following
Failed to set patch values from Metadata. Default values will be used.
InstallMSUpdates : Install failed with ResultCode 4 and HResult -2145124318
At C:\Program Files (x86)\Automox\execDir149571395\execcmd013954502.ps1:1788 char:21
+                     InstallMSUpdates $lst
    + CategoryInfo          : NotSpecified: (:) [Write-Error], WriteErrorException
    + FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,InstallMSUpdates
Any ideas on way some will update while others have this error?
Best answer by JohnG-Automox
Hi @CallmePH,
Please submit a ticket to our Support team for this so they can investigate further: https://help.automox.com/
Thanks!
View original
JohnG-Automox
  • 121 replies
  • Answer
  • June 11, 2024
Hi @CallmePH,
Thanks!
CallmePH
  • Pro
  • 52 replies
  • June 11, 2024
Done and done thanks!
  • 2 replies
  • June 13, 2024
Was there any updates to the ticket you created? We’ve been seeing the same this for a couple of weeks.
CallmePH
  • Pro
  • 52 replies
  • June 13, 2024
Yes! My issue at least was linked to the 22H2 update that required a 250MB recovery partition.  Linked the issue below. I have since ignored the patch and we are not seeing that error.
https://support.microsoft.com/en-au/topic/kb5034441-windows-recovery-environment-update-for-windows-10-version-21h2-and-22h2-january-9-2024-62c04204-aaa5-4fee-a02a-2fdea17075a8
  • 2 replies
  • June 13, 2024
Thanks for the quick response! I guess I’ll go submit a ticket with them so they can investigate. We’re getting this error on many different patches.
We did run into the KB5034441 patch issues as well a while back but we managed to get those fixed using worklets.
CallmePH
  • Pro
  • 52 replies
  • June 13, 2024
I have opened another, seeing the same error when trying different packages, Google Chrome for one. If I get an update I will let you know!
  • 5 replies
  • July 8, 2024
Hi @jfrancisco
Do you mind putting the worklet here? Tried creating a worklet using Microsoft provided script but I keep getting “unexpected user input” error
pplacide
  • 4 replies
  • September 19, 2024
You can use this script as remediation code fix the recovery drive issue with KB5034441
Param (
[Parameter(Mandatory=$false,HelpMessage="Skip confirmation")][bool]$SkipConfirmation=$true,
[Parameter(Mandatory=$false,HelpMessage="Path to backup old WinRE partition content to")][string]$BackupFolder
# Helper functions
# Log message
function LogMessage([string]$message)
	$message = "$message"
	Write-Host $message
# Extract numbers from string
function ExtractNumbers([string]$str)
	$cleanString = $str -replace "[^0-9]"
	return [long]$cleanString
# Display partition info using fsutil
# Return an array, the first value is total size and the second value is free space
function DisplayPartitionInfo([string[]]$partitionPath)
	$volume = Get-WmiObject -Class Win32_Volume | Where-Object { $partitionPath -contains $_.DeviceID }
	LogMessage("  Partition capacity: " +  $volume.Capacity)
	LogMessage("  Partition free space: " + $volume.FreeSpace)
	return $volume.Capacity, $volume.FreeSpace
# Display WinRE status
function DisplayWinREStatus()
	# Get WinRE partition info
	$WinREInfo = Reagentc /info
	foreach ($line in $WinREInfo)
		$params = $line.Split(':')
		if ($params.Count -lt 2)
			continue
		if (($params[1].Trim() -ieq "Enabled") -Or (($params[1].Trim() -ieq "Disabled")))
			$Status = $params[1].Trim() -ieq "Enabled"
			LogMessage($line.Trim())
		if ($params[1].Trim() -like "\\?\GLOBALROOT*")
			$Location = $params[1].Trim()
	return $Status, $Location
# Main execution
$BackupFolder = "C:\ProgramData\BKFixKB503441"
# Create BackupFolber if not exist
if (-not (Test-Path $BackupFolder)) {
    New-Item -Path $BackupFolder -ItemType Directory -Force
# Clear the error
$Error.Clear()
# Examining the system to collect required info
# for the execution
# Need to check WinRE status, collect OS and WinRE
# partition info
LogMessage("Start time: $([DateTime]::Now)")
LogMessage("Examining the system...")
$NeedShrink = $true
$NeedCreateNew = $false
$NeedBackup = $false
$InitialWinREStatus = DisplayWinREStatus
$WinREStatus = $InitialWinREStatus[0]
$WinRELocation = $InitialWinREStatus[1]
if (!$WinREStatus)
	LogMessage("Error: WinRE Disabled")
	exit 1
# Get System directory and ReAgent xml file
$system32Path = [System.Environment]::SystemDirectory
LogMessage("System directory: " + $system32Path)
$ReAgentXmlPath = Join-Path -Path $system32Path -ChildPath "\Recovery\ReAgent.xml"
LogMessage("ReAgent xml: " + $ReAgentXmlPath)
if (!(Test-Path  $ReAgentXmlPath))
	LogMessage("Error: ReAgent.xml cannot be found")
	exit 1
# Get OS partition
LogMessage("")
LogMessage("Collecting OS and WinRE partition info...")
$OSDrive = $system32Path.Substring(0,1)
$OSPartition = Get-Partition -DriveLetter $OSDrive
$WinRELocationItems = $WinRELocation.Split('\\')
foreach ($item in $WinRELocationItems)
    if ($item -like "harddisk*")
		$OSDiskIndex = ExtractNumbers($item)
	if ($item -like "partition*")
		$WinREPartitionIndex = ExtractNumbers($item)
LogMessage("OS Disk: " + $OSDiskIndex)
LogMessage("OS Partition: " + $OSPartition.PartitionNumber)
LogMessage("WinRE Partition: " + $WinREPartitionIndex)
$WinREPartition = Get-Partition -DiskNumber $OSDiskIndex -PartitionNumber $WinREPartitionIndex
$diskInfo = Get-Disk -number $OSDiskIndex
$diskType = $diskInfo.PartitionStyle
LogMessage("Disk PartitionStyle: " + $diskType)
# Display WinRE partition size info
LogMessage("WinRE partition size info")
$WinREPartitionSizeInfo = DisplayPartitionInfo($WinREPartition.AccessPaths)
LogMessage("WinRE Partition Offset: " + $WinREPartition.Offset)
LogMessage("WinRE Partition Type: " + $WinREPartition.Type)
LogMessage("OS partition size: " + $OSPartition.Size)
LogMessage("OS partition Offset: " + $OSPartition.Offset)
$OSPartitionEnds = $OSPartition.Offset + $OSPartition.Size
LogMessage("OS partition ends at: " + $OSPartitionEnds)
LogMessage("WinRE partition starts at: " + $WinREPartition.Offset)
$WinREIsOnSystemPartition = $false
if ($diskType -ieq "MBR")
	if ($WinREPartition.IsActive)
		LogMessage("WinRE is on System partition")
		$WinREIsOnSystemPartition = $true
if ($diskType -ieq "GPT")
	if ($WinREPartition.Type -ieq "System")
# Checking the BackupFolder parameter
if ($PSBoundParameters.ContainsKey('BackupFolder'))
	LogMessage("")
	LogMessage("Backup Directory: [" + $BackupFolder + "]")
	$Needbackup = $true
	if ($WinREIsOnSystemPartition)
		$Needbackup = $false
		LogMessage("WinRE is on System partition which will be preserved. No need to backup content")
	else
		if (Test-path $BackupFolder)
			$items = Get-ChildItem -Path $BackupFolder
			if ($items)
				LogMessage("Error: Existing backup directory is not empty")
				exit 1
		else
			LogMessage("Creating backup directory...")
			try
				$item = New-Item -Path $BackupFolder -ItemType Directory -ErrorAction Stop
				if ($item)
					LogMessage("Backup directory created")
				else
					LogMessage("Error: Failed to create backup directory [" + $BackupFolder + "]")
					exit 1
			} catch
				LogMessage("Error: An error occurred: $_")
				exit 1
# Verify whether we meet requirements of execution
# - WinRE cannot be on OS partition for the extension
# - WinRE partition must be the next partition after OS partition
# - If WinRE partition already have >=250MB free space, no need to do repartition
# - If there is enough unallocated space to grow the WinRE partition size, skip shrinking OS
# However, if the WinRE partition is before the OS partition, there is no chance to extend it
# As a result, it's better to create a new WinRE partition after the OS partition
# Perform a few checks
LogMessage("")
LogMessage("Verifying if the WinRE partition needs to be extended or not...")
if (!(($diskType -ieq "MBR") -Or ($diskType -ieq "GPT")))
	LogMessage("Error: Got an unexpected disk partition style: " +$diskType)
	exit 1
# WinRE partition must be after OS partition for the repartition
if ($WinREPartitionIndex -eq $OSPartition.PartitionNumber)
	LogMessage("WinRE and OS are on the same partition, should not perform extension")
$supportedSize = Get-PartitionSupportedSize -DriveLetter $OSDrive
# if there is enough free space, skip extension
if ($WinREPartitionSizeInfo[1] -ge 250MB)
	LogMessage("More than 250 MB of free space was detected in the WinRE partition, there is no need to extend the partition")
if ($WinREPartition.Offset -lt $OSPartitionEnds)
	LogMessage("WinRE partition is not after OS partition, cannot perform extension")
	LogMessage("Need to create a new WinRE partition after OS partition")
	$NeedCreateNew = $true
	$NeedShrink = $true
	# Calculate the size of repartition
	# Will create a new WinRE partition with current WinRE partition size + 250 MB
	# The OS partition size will be shrunk by the new WinRE partition size
	$targetWinREPartitionSize = $WinREPartitionSizeInfo[0] + 250MB
	$shrinkSize = [Math]::Ceiling($targetWinREPartitionSize / 1MB) * 1MB
	$targetOSPartitionSize = $OSPartition.Size - $shrinkSize
	if ($targetOSPartitionSize -lt $supportedSize.SizeMin)
		LogMessage("Error: The target OS partition size after shrinking is smaller than the supported minimum size, cannot perform the repartition")
		exit 1
else
		LogMessage("WinRE parititon is after the OS partition and it's also System partition")
		LogMessage("Error: Got unexpected disk layout, cannot proceed")
		exit 1
	if (!($WinREPartitionIndex -eq ($OSPartition.PartitionNumber + 1)))
		LogMessage("Error: WinRE partition is not right after the OS partition, cannot extend WinRE partition")
		exit 1
	# Will shrink OS partitition by 250 MB
	$shrinkSize = 250MB
	$UnallocatedSpace = $WinREPartition.Offset - $OSPartitionEnds;
	# If there is unallocated space, consider using it
	if ($UnallocatedSpace -ge 250MB)
		LogMessage("Found unallocated space between OS and WinRE partition: " + $UnallocatedSpace)
		LogMessage("There is already enough space to extend WinRE partition without shrinking the OS partition")
		$NeedShrink = $false
		$targetOSPartitionSize = 0
	else
		$shrinkSize = [Math]::Ceiling((250MB - $UnallocatedSpace)/ 1MB) * 1MB
		if ($shrinkSize > 250MB)
			$shrinkSize = 250MB
			exit 1
# Report execution plan and ask for user confirmation to continue
# Report the changes planned to be executed, waiting for user confirmation
LogMessage("")
LogMessage("Summary of proposed changes")
if ($NeedCreateNew)
	LogMessage("Note: WinRE partition is before OS partition, need to create a new WinRE partition after OS partition")
	LogMessage("Will shrink OS partition by " + $shrinkSize)
	LogMessage("  Current OS partition size: " + $OSPartition.Size)
	LogMessage("  Target OS partition size after shrinking: " + $targetOSPartitionSize)
	LogMessage("New WinRE partition will be created with size: ", $targetWinREPartitionSize)
		LogMessage("Existing WinRE partition is also system partition, it will be preserved")
	else
		LogMessage("Existing WinRE partition will be deleted")
		LogMessage("  WinRE partition: Disk [" + $OSDiskIndex + "] Partition [" + $WinREPartitionIndex + "]")
		LogMessage("  Current WinRE partition size: " + $WinREPartitionSizeInfo[0])
else
	if ($NeedShrink)
		if ($UnallocatedSpace -ge 0)
			LogMessage("Unallocated space between OS and WinRE partition that will be used towards the new WinRE partition: " + $UnallocatedSpace)
	else
		LogMessage("Will use 250MB from unallocated space between OS and WinRE partition")
	LogMessage("Will extend WinRE partition size by 250MB")
	LogMessage("  New WinRE partition size:     " + $targetWinREPartitionSize)
	LogMessage("WinRE will be temporarily disabled before extending the WinRE partition and enabled automatically in the end")
	if ($UnallocatedSpace -ge 100MB)
		LogMessage("Warning: More than 100MB of unallocated space was detected between the OS and WinRE partitions")
		LogMessage("Would you like to proceed by using the unallocated space between the OS and the WinRE partitions?")
if ($Needbackup)
	LogMessage("")
	LogMessage("The contents of the old WinRE partition will be backed up to [" + $BackupFolder + "]")
LogMessage("")
LogMessage("Please reboot the device before running this script to ensure any pending partition actions are finalized")
LogMessage("")
if ($SkipConfirmation)
	LogMessage("User chose to skip confirmation")
	LogMessage("Proceeding with changes...")
else
	$userInput = Read-Host -Prompt "Would you like to proceed? Y for Yes and N for No"
	if ($userInput -ieq "Y")
	elseif ($userInput -ieq "N")
		LogMessage("Canceling based on user request, no changes were made to the system")
	else
		LogMessage("Error: Unexpected user input: [" + $userInput + "]")
LogMessage("")
LogMessage("Note: To prevent unexpected results, please do not interrupt the execution or restart your system")
# Do the actual execution
# The main flow is:
# 1. Check whether ReAgent.xml has stage location and clear it for repartiion
# 2. Disable WinRE as WinRE partition will be deleted
# 3. Perform the repartition to create a larger WinRE partition
# 4. Re-enable WinRE
LogMessage("")
# Load ReAgent.xml to clear Stage location
LogMessage("Loading [" + $ReAgentXmlPath + "] ...")
$xml = [xml](Get-Content -Path $ReAgentXmlPath)
$node = $xml.WindowsRE.ImageLocation
if (($node.path -eq "") -And ($node.guid -eq "{00000000-0000-0000-0000-000000000000}") -And ($node.offset -eq "0") -And ($node.id -eq "0"))
	LogMessage("Stage location info is empty")
else
	LogMessage("Clearing stage location info...")
	$node.path = ""
	$node.offset = "0"
	$node.guid= "{00000000-0000-0000-0000-000000000000}"
	$node.id="0"
	# Save the change
	LogMessage("Saving changes to [" + $ReAgentXmlPath + "]...")
	$xml.Save($ReAgentXmlPath)
# Disable WinRE
LogMessage("Disabling WinRE...")
reagentc /disable
if (!($LASTEXITCODE -eq 0))
	LogMessage("Warning: encountered an error when disabling WinRE: " + $LASTEXITCODE)
	exit $LASTEXITCODE
# Verify WinRE is under C:\Windows\System32\Recovery\WinRE.wim
$disableWinREPath = Join-Path -Path $system32Path -ChildPath "\Recovery\WinRE.wim"
LogMessage("Verifying that WinRE wim exists in downlevel at default location")
if (!(Test-Path $disableWinREPath))
	LogMessage("Error: Cannot find " + $disableWinREPath)
	# Re-enable WinRE
	LogMessage("Re-enabling WinRE on error...")
	reagentc /enable
		LogMessage("Warning: encountered an error when enabling WinRE: " + $LASTEXITCODE)
	exit 1
# Perform the repartition
# 1. Resize the OS partition
# 2. Delete the WinRE partition
# 3. Create a new WinRE partition
LogMessage("Performing repartition to extend the WinRE partition ...")
if ($NeedShrink)
	LogMessage("Shrinking the OS partition to create a larger WinRE partition")
	LogMessage("Resizing the OS partition to: [" + $targetOSPartitionSize + "]...")
	Resize-Partition -DriveLetter $OSDrive -Size $targetOSPartitionSize
	if ($Error.Count -gt 0) {
		LogMessage("Error: Resize-Partition encountered errors: " + $Error[0].Exception.Message)
		# Re-enable WinRE
		reagentc /enable
		exit 1
	$OSPartitionAfterShrink = Get-Partition -DriveLetter $OSDrive
	LogMessage("Target partition size: " + $targetOSPartitionSize)
	LogMessage("Size of OS partition after shrinking: " + $OSPartitionAfterShrink.Size)
LogMessage("")
	LogMessage("Existing WinRE partition is System partition, skipping deletion")
else
	# If requested by user, backup rest of the content on WinRE partition to backup directory
	if ($Needbackup)
		$sourcePath = $WinREPartition.AccessPaths[0]
		LogMessage("Copying content on WinRE partition from [" + $sourcePath + "] to [" + $BackupFolder + "]...")
		# Copy-Item may have access issue with certain system folders, enumerate the children items and exlcude them
		$items = Get-ChildItem -LiteralPath $sourcePath -Force
		foreach ($item in $items)
			if ($item.Name -ieq "System Volume Information")
				continue
			$sourceItemPath = Join-Path -Path $sourcePath -ChildPath $item.Name
			$destItemPath = Join-Path -Path $BackupFolder -ChildPath $item.Name
			try
				LogMessage("Copying [" + $sourceItemPath + "] to [" + $destItemPath + "]...")
				Copy-Item -LiteralPath $sourceItemPath -Destination $destItemPath -Recurse -Force
			} catch
				LogMessage("Error: An error occurred during copy: $_")
				exit 1
		LogMessage("Backup completed")
		LogMessage("")
	LogMessage("Deleting WinRE partition: Disk [" + $OSDiskIndex + "] Partition [" + $WinREPartitionIndex + "]...")
	Remove-Partition -DiskNumber $OSDiskIndex -PartitionNumber $WinREPartitionIndex -Confirm:$false
		LogMessage("Error: Remove-Partition encountered errors: " + $Error[0].Exception.Message)
		exit 1
# A short sleep for the partition change
Sleep 5
LogMessage("")
LogMessage("Creating new WinRE partition...")
LogMessage("Target size: " + $targetWinREPartitionSize)
	$partition = New-Partition -DiskNumber $OSDiskIndex -Size $targetWinREPartitionSize -GptType "{de94bba4-06d1-4d40-a16a-bfd50179d6ac}"
	$newPartitionIndex = $partition.PartitionNumber
	# A short sleep to make sure the partition is ready for formatting
	Sleep 2
	LogMessage("Formating the partition...")
	$result = Format-Volume -Partition $partition -FileSystem NTFS -Confirm:$false
		LogMessage("Error: Format-Volume encountered errors: " + $Error[0].Exception.Message)
		exit 1
else
	#$partition = New-Partition -DiskNumber $OSDiskIndex -Size $targetWinREPartitionSize -MbrType 0x27
	$targetWinREPartitionSizeInMb = [int]($targetWinREPartitionSize/1MB)
	$diskpartScript =
select disk $OSDiskIndex
create partition primary size=$targetWinREPartitionSizeInMb id=27
format quick fs=ntfs label="Recovery"
set id=27
	$TempPath = $env:Temp
	$diskpartSciptFile = Join-Path -Path $TempPath -ChildPath "\ExtendWinRE_MBR_PowershellScript.txt"
	LogMessage("Creating temporary diskpart script to create Recovery partition on MBR disk...")
	LogMessage("Temporary diskpart script file: " + $diskpartSciptFile)
	$diskpartScript | Out-File -FilePath $diskpartSciptFile -Encoding ascii
	LogMessage("Executing diskpart script...")
	try
		$diskpartOutput = diskpart /s $diskpartSciptFile
		if ($diskpartOutput -match "DiskPart successfully")
			LogMessage("Diskpart script executed successfully")
		else
			LogMessage("Error executing diskpart script:" + $diskpartOutput)
			exit 1
		LogMessage("Deleting temporary diskpart script file...")
		Remove-Item $diskpartSciptFile
	catch
		LogMessage("Error executing diskpart script: $_")
		exit 1
	$vol = Get-Volume -FileSystemLabel "Recovery"
	$newPartitionIndex = (Get-Partition | Where-Object { $_.AccessPaths -contains $vol.Path } ).PartitionNumber
	LogMessage("Error: New-Partition encountered errors: " + $Error[0].Exception.Message)
	exit 1
LogMessage("New Partition index: " + $newPartitionIndex)
# Re-enable WinRE
LogMessage("Re-enabling WinRE...")
reagentc /enable
	exit $LASTEXITCODE
# In the end, Display WinRE status to verify WinRE is enabled correctly
LogMessage("")
LogMessage("WinRE Information:")
$FinalWinREStatus = DisplayWinREStatus
$WinREStatus = $FinalWinREStatus[0]
$WinRELocation = $FinalWinREStatus[1]
if (!$WinREStatus)
	LogMessage("Warning: WinRE Disabled")
LogMessage("WinRE Partition Index: " + $WinREPartitionIndex)
$WinREPartitionSizeInfoAfter = DisplayPartitionInfo($WinREPartition.AccessPaths)
LogMessage("")
LogMessage("OS Information:")
if (!($WinREPartitionIndex -eq $newPartitionIndex))
	LogMessage("Warning: WinRE is installed to partition [" + $WinREPartitionIndex +"], but the newly created Recovery partition is [" + $newPartitionIndex + "]")
LogMessage("End time: $([DateTime]::Now)")
if ($NeedBackup)
	LogMessage("")
	LogMessage("The contents of the old WinRE partition has been backed up to [" + $BackupFolder + "]")
LogMessage("")
LogMessage("Successfully completed the operation")
Cookie policy
Cookie settings
