Answer
Does Automox Use x86 powershell?
  • April 5, 2022
  • 658 views
TJ_Coppola
I’m attempting to script a LAPS installation which requires the creation of a local account. When I test the powershell script on my local machine everything works great. When I tried to run it through Automox I get an error.
Get-LocalGroupMember : The term 'Get-LocalGroupMember' is not recognized as
the name of a cmdlet, function, script file, or operable program. Check the
spelling of the name, or if a path was included, verify that the path is
correct and try again.
At C:\ProgramData\amagent\execDir691746467\execcmd943937958.ps1:3 char:15
+ $isingorup = (Get-LocalGroupMember $group).Name -Contains $user
+ CategoryInfo : ObjectNotFound: (Get-LocalGroupMember:String) []
, CommandNotFoundException
New-LocalUser : The term 'New-LocalUser' is not recognized as the name of a
cmdlet, function, script file, or operable program. Check the spelling of the
name, or if a path was included, verify that the path is correct and try again.
At C:\ProgramData\amagent\execDir691746467\execcmd943937958.ps1:6 char:1
+ New-LocalUser "CTPAdmin" -Password $password -Description "Local Admi ...
+ CategoryInfo : ObjectNotFound: (New-LocalUser:String) [], Comma
ndNotFoundException
Add-LocalGroupMember : The term 'Add-LocalGroupMember' is not recognized as
At C:\ProgramData\amagent\execDir691746467\execcmd943937958.ps1:7 char:1
+ Add-LocalGroupMember -Group $group -Member "CTPAdmin"
+ CategoryInfo : ObjectNotFound: (Add-LocalGroupMember:String) []
COMMAND TIMED OUT.
When looking up the possible cause of this error I found that the Microsoft.Powershell.LocalAccounts module is only available with powershell x64.
Does Automox use x86 powershell and if so is a x64 powershell available?
Best answer by jack.smith
Sure does. There is a way to execute 64-bit PowerShell. To do that, checkout https://support.automox.com/help/enforce-windows-registry-settings-worklet just under the “64-Bit Registry Workaround” section or see the 64-bit example below.
Before that, the net commands still work for x86 powershell
net user ITAdmin $password /ADD /Y
net localgroup Administrators ITAdmin /ADD
Here is a 64-bit example
$scriptblock = {
############# EDIT HERE ############
$account = "ITAdmin"
$description = "IT local admin account"
# Function to generate Random Passwords
function New-RandomPassword {
param(
[Parameter()]
[int]$MinimumPasswordLength = 18,
[Parameter()]
[int]$MaximumPasswordLength = 29,
[Parameter()]
[int]$NumberOfAlphaNumericCharacters = 9,
[Parameter()]
[switch]$ConvertToSecureString
Add-Type -AssemblyName 'System.Web'
$length = Get-Random -Minimum $MinimumPasswordLength -Maximum $MaximumPasswordLength
$password = [System.Web.Security.Membership]::GeneratePassword($length,$NumberOfAlphaNumericCharacters)
if ($ConvertToSecureString.IsPresent) {
ConvertTo-SecureString -String $password -AsPlainText -Force
} else {
$password
# Generate random password
$pw = ConvertTo-SecureString "$(New-RandomPassword)" -AsPlainText -Force
# Create User Account and Add to Administrator Group
New-LocalUser $account -Password $pw -FullName $account -Description $description -verbose
Add-LocalGroupMember -Group Administrators -Member $account -verbose
# Validate Account was created
$ac = Get-LocalUser $account
IF($ac){
$grp = Get-LocalGroupMember Administrators
IF($grp){
# Account exists and is a local admin
return 0
}else{
# Account exists but is not a local admin
return 2
}else{
# Account doesn't exist return 1
return 1
# Run scriptblock in 64-bit powershell
$64bit = & "$env:SystemRoot\sysnative\WindowsPowerShell\v1.0\powershell.exe" -ExecutionPolicy Bypass -WindowStyle Hidden -NoProfile -NonInteractive -Command $scriptblock
$out = switch ($64bit)
0 {"Succesfully created $account and added to local admin group"}
1 {"Failed to create $account"}
2 {"Succesfully created $account and failed to add to local admin group"}
Default {"$64bit"}
Write-Output $out
Exit $64bit
shameless plug... you should also check out
jack.smith
Forum|alt.badge.img+1
  • All Star
  • Answer
  • April 6, 2022
$scriptblock = {
param(
[Parameter()]
[Parameter()]
[Parameter()]
[Parameter()]
} else {
$password
IF($ac){
IF($grp){
return 0
}else{
return 2
}else{
return 1
Default {"$64bit"}
Write-Output $out
Exit $64bit
TJ_Coppola
  • Pro
  • April 6, 2022
Thank you so much! This is perfect.
TJ_Coppola
  • Pro
  • April 12, 2022
Wouldn’t the following line require more specificity if it’s to validate that the account is within the admin group? It looks like it only checks if there are any administrators at all.
Does this change improve the effectiveness?
$grp = Get-LocalGroupMember Administrators | Where-Object {$_.name -like "*$Account*"}
