Change Automox Script Execution Location
  • October 4, 2019
  • 0 replies
  • 24 views
If you’d like your worklets (and other agent commands) to execute from a different location, here’s how you do that:
https://support.automox.com/help/automox-agent-requirements
The most common reason you’d use this is if your endpoint security is blocking the default execution location for the agent.
