API Question
  • April 2, 2020
  • 4 replies
  • 24 views
I am wanting to build out a detailed Splunk Dashboard. Is there a way in the API to get a list or count of devices needing a patch based on severity? Like showing all the machines with Critical Patches
MinnesotaJoe
If you call reports/prepatch you get this:
And below a list of the devices.
Is that what you are looking for?
  • April 2, 2020
So is the prepatch per machine or per total count? I have pulled that but I only seem to get a few machines… But yes that does seem to be closer to my goal… Thanks!
MinnesotaJoe
Total is how many total patches need to be pushed (This could be the same patch listed multiple times adding up)
Then each is the count below that for the same.
So in my screenshot. The 4 other, could be 4 separate patches, or the same patch needed on 4 machines.
  • April 2, 2020
That’s what I need Thanks
