Introducing Otto AI - your professional script consultant!
  • 18 July 2023
  • 0 replies
  • 54 views
Userlevel 3
We’re so excited to introduce Otto AI!
If you’re struggling to automate repetitive manual work like device configuration, our all-new Otto AI script-writing assistant can help!
Fueled by OpenAI’s GPT large language model, Otto AI accelerates your scripting in PowerShell and Bash so you don’t have to start from scratch.
Just Ask Otto, the in-console AI assistant, to help you quickly create custom scripts that you can test, refine, and automate across your IT environment. Ask Otto, go fast, and confidently write scripts that save you hours!
Check it out! Then, let us know how you’re liking it. Be sure to share any Worklets you’ve made using Otto AI in our Find & Share Worklets category!
Be the first to reply!
