Solved
Tag based on Device Info?
  • December 5, 2022
  • 2 replies
  • 251 views
i’m just getting my feet wet with Automox, and i see a lot of recent enhancements have been made with regard to Tagging, but i’m wondering if there’s a way to auto-assign tags in bulk based on device info?  My use case would be to automatically tag devices based on their AD OU.  If i’ve got a device in the “San Francisco Office” OU in AD, that shows in the Device Info in Automox, so is there some script or worklet i could use to automatically tag all devices reflecting that device info?  thanks!
Best answer by ElmerP-Automox
Hello,
If you intend on using tags to target specific devices in your policies, you could instead leverage the ‘Active Directory Organizational Unit’ attribute available in ‘Device Targeting’ in a policy.
Hope this helps.
  • Answer
  • December 6, 2022
Hello,
Hope this helps.
  • December 6, 2022
brilliant, that gets me what i need, thanks!
