Solved
Installing msi package using required software
  • February 28, 2024
  • 361 views
Hello everyone. I have been trying to find some examples, and I thought what I put would work, but its not. I am trying to install an msi package that has some extra arguments. For example, If I run this from a command line it works on a computer:
msiexec /i agentmanagersetup.msi /qn DEVREGCODE=XXXX TENANT=XXXX ALLUSERS=1
When using automox it has me do some of this in quotes and parentheses and this is where I am not sure what to do. I currently have this but its not working:
exit (Start-Process -FilePath 'msiexec.exe' -ArgumentList ('/qn', '/i', '"agentmanagersetup.msi DEVREGCODE=XXXX TENANT=XXXX ALLUSERS=1"') -Wait -Passthru).ExitCode
If I removed the DEVREGCODE and TENANT arguments and put them in their own quotes i would get an error about a token. If i put it the way I have it above, it doesnt seem like its running as i dont even see a failed in the activity report.
Not sure What I am doing wrong. Also, because the install has specific to our company, I replaced that data with the X’s.
Best answer by jack.smith
Give this a try.
$install = Start-Process -FilePath msiexec.exe -ArgumentList ('/i agentmanagersetup.msi DEVREGCODE=XXXX TENANT=XXXX ALLUSERS=1 /qn') -Wait -Passthru
Write-Output "Install ExitCode: $($install.ExitCode)"
jack.smith
Forum|alt.badge.img+1
  • All Star
  • Answer
  • March 1, 2024
Give this a try.
  • March 1, 2024
Thank you. I will give this a try.
  • March 4, 2024
That worked, thank you very much.
