Activity log not showing output for below worklet.
  • April 10, 2024
  • 217 views
Hi all, im trying to fetch those system update packages from endpoints. im doing this via this worklet here , for some reason its not showing output in Automox console. can anyone suggest what am i doing wrong here.. i also have same problem for other command Test-PendingReboot -detailed to when i try to verify if endpoint is waiting for a reboot or not..  i also checked out this too and ive tried both standard output stream PowerShell: Write-Output/Write-Host but none of it worked.. just getting an empty box in log summary. Any help would be highly appreciated.
# Check if the PSWindowsUpdate module is installed, if not, install it
if (-not (Get-Module -Name PSWindowsUpdate -ListAvailable)) {
    Install-Module -Name PSWindowsUpdate -Force -AllowClobber -Scope CurrentUser -Repository PSGallery
# Import the PSWindowsUpdate module
Import-Module PSWindowsUpdate
# Get a list of available updates
$updates = Get-WindowsUpdate
# Iterate through each update
foreach ($update in $updates) {
    $title = $update.Title
    $status = $update.InstallationStatus
    $rebootRequired = $update.RebootRequired
    $isDownloading = $update.IsDownloaded
    $isInstalling = $update.IsInstalling
    $errorCode = $update.ErrorCode
    Write-Host "Update Title: $title"
    if ($status -eq "Pending") {
        Write-Host "Status: Waiting to Install"
    } elseif ($status -eq "Downloading") {
        Write-Host "Status: Currently Downloading"
    } elseif ($status -eq "Installing") {
        Write-Host "Status: Currently Installing"
    } elseif ($status -eq "Installed") {
        Write-Host "Status: Installed"
    } elseif ($status -eq "Failed") {
        Write-Host "Status: Failed to Install"
        Write-Host "Error Code: $errorCode"
    } elseif ($status -eq "Error") {
        Write-Host "Status: Error"
    if ($rebootRequired) {
        Write-Host "Reboot Required: Yes"
    } else {
        Write-Host "Reboot Required: No"
    if ($isDownloading) {
        Write-Host "Downloaded: Yes"
    } else {
        Write-Host "Downloaded: No"
    if ($isInstalling) {
        Write-Host "Installing: Yes"
    } else {
        Write-Host "Installing: No"
    Write-Host "==============================="
  • April 10, 2024
i believe you have to use Write-Output instead of write-host
  • Pro
  • April 10, 2024
@asolorio i did try that. No luck so far.
jack.smith
Forum|alt.badge.img+1
  • All Star
  • April 10, 2024
I’d add in a line to catch exceptions if say the cmdlet “Get-WindowsUpdate” returns nothing at all.
IF(!$updates){Write-Output "Did not detect updates"}
You could also do this to see what it might be doing.
Start-Transcript C:\Windows\Temp\Worklet-Code-Test.log
# your worklet code
Stop-Transcript
Get-Content C:\Windows\Temp\Worklet-Code-Test.log
I’m a huge fan of PSExec and launching powershell locally in 32-bit mode to test worklets in real time before dropping them into Automox. Here is the command I’d use for that:
psexec -s -i -d C:\windows\SysWOW64\WindowsPowerShell\v1.0\powershell_ise.exe
