Solved
Required Software Scheduling...
  • 20 June 2022
  • 2 replies
  • 134 views
Hello,
When scheduling a Required Software policy, would you set it to run literally every month, every week and every day?  Or is scheduling it once enough?  I ask this because my thinking tells me it’ll run once and then never again - if the software were to be installed by Automox, then removed by a user, the policy wouldn’t pick it up again.  Or at least not until that singular schedule day arrived again in a years time.
Or is is best to schedule a Required Software policy to run once every week if this is the case?
Cheers,
Mark.
icon
Best answer by ElmerP-Automox 21 June 2022, 14:43
View original
Userlevel 1
Hello,
Your thinking is correct. If you would like to check on a weekly basis that the Required Software is installed on a Device, you should then schedule that Policy to run once a week. If the Policy is only run once, it will not catch a possible uninstallation action by a User.
Kind regards,
Elmer
Thanks for confirming!
