Solved
Need to update zoom workplace on 25 devices asap
Hi
What is best possible way in automox to update zoom workspace to latest version on 25 devices.
Best answer by AX-CoreyMesenbring
Clicking “Patch Now” from the Software page will attempt to install the patch on any devices that are listed under “Impacted” and are online. If you need to be more specific about which devices receive the patch, you can either enable Device Targeting on a configured Patch Policy, or if you navigate to the software table at the bottom of the device detail page, you could manually install the patch by selecting it from the list. I hope this helps!
View original
Hey sac548! There are a couple of ways to tackle patching a specific software title across your environment. You could:
  • Configure and run a Patch Policy configured to target Zoom (likely a Patch Only Policy)
  • Navigate to the Software page under the "Manage" tab in the Console, find the latest version of Zoom, and click "Patch Now" (click the 3 dots in the actions column)
There are a few other ways of accomplishing this, but in my opinion, one of the 2 methods listed above would be the easiest. I'll also point out that Zoom updates (for Windows) will fail if users are in a call when the patch is initiated, unless you have configured overrides. Check out this article for more information on the expected behavior for patching applications that are open. Please let me know if you have any other questions!
  • August 14, 2025
Will it give me option to select custom device or run on demand when I click on “Patch now” ?
