Solved
MS SQL Patching
  • October 10, 2019
  • 4 replies
  • 569 views
Has anyone created a policy specifically for patching MS SQL servers?
Best answer by ChrisW-Automox
We haven’t created a policy like that yet, but I have a feeling we will soon. Some DBAs are hesitant to take SQL Server patches right away.
I would create a “Patch Only” policy and filter the list for anything with the words “SQL Server”. From there, select the patches you want to allow to be deployed.
View original
  • October 10, 2019
Those patches come through Windows Update, so they should get applied automatically to any Windows machine that qualifies. You shouldn’t need a special policy that differs from your normal Windows policy. Does that give you what you need? Or are you wanting to do something different specifically with your MS SQL servers?
ChrisW-Automox
  • October 11, 2019
Thanks @Chris - I’m guessing @rwagner’s situation is probably similar to yours, so that’s very helpful!
  • Channel Partner
  • October 21, 2019
Thank you very much for your responses! They have been very helpful
