Solved
Agent installation issues.
  • March 3, 2023
  • 535 views
I am trying to deploy Automox agent on windows 10/11 clients via SmartDeploy Console. The Agent installs but not checking into Automox dashboard. I don’t see the device at all. I have the command setup with the installation of the msi as follows:
msiexec.exe /i "[ApplicationsFolder]\Automox Agent\Files\Application Packs\Automox_Installer-1.42.13.msi" /qn /norestart ACESSKEY=#################
What can I do to get the agent to checkin to the dashboard?
Best answer by ElmerP-Automox
Hello,
It might be due to the typo you have in the command. Please retry with ‘ACCESSKEY=#################’
Kind regards,
View original
Hello,
Kind regards,
