Slack integration no longer working
  • April 8, 2022
  • 12 replies
  • 732 views
It seems that about 3 weeks ago my slack integration stopped working. I do not see an automox app in the slack directory. Whats going on and how can I get this working again?
Brittany
  • Pro
  • April 12, 2022
Hey there! Sorry for the delay, I did some digging and there is a known issue with the Slack integration and our team is currently making progress on fixing the issue.
Thanks for your patience!
  • April 19, 2022
Are there any updates on when this might be fixed?
  • April 21, 2022
Having the same issue here.
Any update here?
@Brittany-Automox Can you provide an update? How long is it going to take to get this fixed?
  • May 9, 2022
Would love to know when this is going to be fixed, we (used to) rely on the slack integration heavily for tracking patching failures.
  • May 10, 2022
Hi Folks,
Sorry for the delayed response here - the engineering team has been working on this issue and expects to release the fix in the immediate future.
  • May 18, 2022
Hi all,
seems like I haven’t been the only one experiencing this. I went to reinstall the slack integration after being advised that it would help fix the issue, only to find that I cannot locate the app anymore in the directory.
I then go to the account activity log [in Slack] and I can see that the app was deleted. What is going on?
  • May 18, 2022
Hi acxparrish,
Is this a current issue you are experiencing? If so, I’d recommend you contact support@automox.com. The fixes to the Slack integration were released last week and I’m not aware of any current issues.
  • May 18, 2022
@Ken-Automox Thank you. I have been back and forth with Automox support. Currently, they are presenting the following image to the engineering team.
I can no longer click on it to view the app directory listing
  • June 16, 2022
Update from Automox Support:
Our team has been working on this issue. Unfortunately, the two people working on this matter are no longer with the company. I am working to find another team to handle this issue for you. I will keep you posted on what is happening.
Where are we on this please?
