Is there any update on macOS Monterey 12.0.1 being available within Automox? I would like to be able to disable this in my patching policies until it is supported within our other products.
I don’t see it when I search for “macOS”, check the mac OS checkbox, or search for “Monterey”. Would it be safe to add these exemption keywords in without it being present in the software library?
Automox will not upgrade your machine from Big Sur to Monterey. You need to defer the update or block it via your MDM.
That’s fantastic news. Assuming AMX is still supported once we eventually roll to Monterey then?
It is supported, I’m on Monterey using Automox without any issues 🙂
can you please share the worklet which worked for upgrade Big sur to Monterey?
