Device Rebooted Automatically Without Reboot Notification
  • November 14, 2024
  • 2 replies
  • 163 views
We have checked the option 'Do not enable automatic restart after updates are installed' in the policy and configured the user notifications as well.
The devices have been patched as per the schedule and are showing 'Need Reboot' in the Automox console. After that, the device was automatically rebooted but has not received the reboot notification.
Please assist with this issue. Attached is the screenshot of the user notification setup for your reference
AX-YazMoreno
  • November 14, 2024
Hello ​@RAHULNATH,
One potential explanation could be a conflicting policy assigned to the same device. You can check this by going to Devices > click on the hostname > Associated policies. If things look good there, I suggest reaching out to support
jack.smith
Forum|alt.badge.img+1
  • All Star
  • November 14, 2024
@RAHULNATH  I’d take a look under Task Scheduler > Microsoft > Windows > UpdateOrchistrator
See if there is a task called reboot and if it aligns with the date and time the device rebooted.
Some code I’ve used  to gleam what’s going on:
#Get Windows Setup Logs
#region Windows Setup Log Files
Write-Output '';write-Output ''
Write-output 'WINDOWS SETUP EVENTS'
$events = Get-WinEvent -FilterHashtable @{
LogName='Setup'
} -MaxEvents 15
Foreach($e in $events){
write-output "$($e.TimeCreated) | $($e.Message)"
#endregion
#Get Uptime
#region Uptime
$uptime = (Get-Date) - (Get-CimInstance Win32_OperatingSystem).LastBootUpTime
Write-Output "Days: $($uptime.Days)"
Write-Output "Hours: $($uptime.Hours)"
Write-Output "Minutes: $($uptime.Minutes)"
#endregion
#Get Reboot History
#region Reboot History
Function Get-RebootHistory {
.SYNOPSIS
Retrieves historical information about shutdown/restart events from one or more remote computers.
.DESCRIPTION
The Get-RebootHistory function uses Windows Management Instrumentation (WMI) to retrieve information about all shutdown events from a remote computer.
Using this function, you can analyze shutdown events across a large number of computers to determine how frequently shutdown/restarts are occurring, whether unexpected shutdowns are occurring and quickly identify the source of the last clean shutdown/restart.
Data returned includes date/time information for all available boot history events (e.g. restarts, shutdowns, unexpected shutdowns, etc.), date/time information for unexpected reboots and detailed information about the last clean shutdown including date/time, type, initiating user, initiating process and reason.
Because Get-RebootHistory uses WMI to obtain shutdown event history from the system event log, it is fully supported against both legacy and current versions of Windows including legacy versions that do not support filtering of event logs through standard methods.
.PARAMETER ComputerName
Accepts a single computer name or an array of computer names separated by commas (e.g. "prod-web01","prod-web02").
This is an optional parameter, the default value is the local computer ($Env:ComputerName).
.PARAMETER Credential
Accepts a standard credential object.
This is an optional parameter and is only necessary when the running user does not have access to the remote computer(s).
.EXAMPLE
.\Get-RebootHistory -ComputerName prod-web01,prod-web02 -Credential (Get-Credential)
Get boot history for multiple remote computers with alternate credentials.
.EXAMPLE
.\Get-RebootHistory -ComputerName prod-web01,prod-web02 -Credential (Get-Credential) | ? { $_.PercentDirty -ge 30 }
Get a list of computers experiencing a high percentage of unexpected shutdown events.
.EXAMPLE
.\Get-RebootHistory -ComputerName prod-web01,prod-web02 -Credential (Get-Credential) | ? { $_.RecentShutdowns -ge 3 }
Return information about servers that have been experiencing frequent shutdown/reboot events over the last 30 days.
.OUTPUTS
System.Management.Automation.PSCustomObject
Return object includes the following properties:
Computer
BootHistory : Array of System.DateTime objects for all recorded instances of the system booting (clean or otherwise).
RecentShutdowns : The number of shutdown/restart events in the last 30 days.
UnexpectedShutdowns : Array of System.DateTime objects for all recorded unexpected shutdown events.
RecentUnexpected : The number of unexpected shutdown events in the last 30 days.
PercentDirty : The percentage of shutdown events that were unexpected (UnexpectedShutdowns/BootHistory).
LastShutdown : System.DateTime object of the last clean shutdown event.
LastShutdownType : Type of the last clean shutdown event (Restart | Shutdown).
LastShutdownUser : The user who initiated the last clean shutdown event.
LastShutdownProcess : The process that initiated the last clean shutdown event.
LastShutdownReason : If available, the reason code and comments for the last clean shutdown event.
.NOTES
Author : Eric Westfall
Email : eawestfall@gmail.com
Script Version : 1.1
Revision Date : 11/26/2014
Param (
[Parameter(Mandatory = $False, Position = 0, ValueFromPipeline = $True, ValueFromPipelineByPropertyName = $True)]
[Alias("CN","Computer")]
[Array]$ComputerName = $Env:ComputerName,
[Parameter(Mandatory = $False, Position = 1, ValueFromPipeline = $False)]
[Alias("Cred")]
[ValidateNotNull()]
[System.Management.Automation.PSCredential]$Credential = [System.Management.Automation.PSCredential]::Empty
Begin {
$i = 0
$RecentShutdowns = 0
$RecentUnexpected = 0
$BootHistory = @()
$ShutdownDetail = @()
$UnexpectedShutdowns = @()
# Store original credential, if we attempt to make a local connection we need to
# temporarily empty out the credential object.
$Original_Credential = $Credential
# Select properties defined to ensure proper display order.
$BootInformation = @(
"Computer"
"BootHistory"
"RecentShutdowns"
"UnexpectedShutdowns"
"RecentUnexpected"
"PercentDirty"
"LastShutdown"
"LastShutdownType"
"LastShutdownUser"
"LastShutdownProcess"
"LastShutdownReason"
# Arguments to be passed to our WMI call.
$Params = @{
ErrorAction = 'Stop'
ComputerName = $Computer
Class = 'Win32_NTLogEvent'
Filter = "LogFile = 'System' and EventCode = 6009 or EventCode = 6008 or EventCode = 1074"
Process {
ForEach ($Computer In $ComputerName) {
$Params.ComputerName = $Computer
# You can't use credentials when connecting to the local machine so temporarily empty out the credential object.
If ($Computer -eq $Env:ComputerName) {
$Params.Credential = [System.Management.Automation.PSCredential]::Empty
If ($ComputerName.Count -gt 1) {
Write-Progress -Id 1 -Activity "Retrieving boot history." -Status ("Percent Complete: {0:N0}" -f $($i / $($ComputerName.Count)*100)) -PercentComplete (($i / $ComputerName.Count)*100); $i++
} Else {
Write-Progress -Id 1 -Activity "Retrieving boot history." -Status "Retrieving boot history."
Try {
$d = 0
$Events = Get-WmiObject @Params
ForEach ($Event In $Events) {
Write-Progress -Id 2 -ParentId 1 -Activity "Processing reboot history." -PercentComplete (($d / $Events.Count)*100) -Status "Processing reboot history."; $d++
# Record the relevant details for the shutdown event.
Switch ($Event.EventCode) {
6009 { $BootHistory += (Get-Date(([WMI]'').ConvertToDateTime($Event.TimeGenerated)) -Format g) }
6008 { $UnexpectedShutdowns += ('{0} {1}' -f ($Event.InsertionStrings[1], $Event.InsertionStrings[0])) }
1074 { $ShutdownDetail += $Event }
# We explicitly ignore exceptions originating from this process since some versions of Windows may store dates in invalid formats (e.g. ?11/?16/?2014) in the event log after an unexpected shutdown causing this calculation to fail.
Try {
$RecentUnexpected = ($UnexpectedShutdowns | ? { ((Get-Date)-(Get-Date $_)).TotalDays -le 30 }).Count
} Catch {
$RecentUnexpected = "Unable to calculate."
# Grab details about the last clean shutdown and generate our return object.
$ShutdownDetail | Select -First 1 | ForEach-Object {
New-Object -TypeName PSObject -Property @{
Computer = $Computer
BootHistory = $BootHistory
RecentUnexpected = $RecentUnexpected
LastShutdownUser = $_.InsertionStrings[6]
UnexpectedShutdowns = $UnexpectedShutdowns
LastShutdownProcess = $_.InsertionStrings[0]
PercentDirty = '{0:P0}' -f (($UnexpectedShutdowns.Count/$BootHistory.Count))
LastShutdownType = (Get-Culture).TextInfo.ToTitleCase($_.InsertionStrings[4])
LastShutdown = (Get-Date(([WMI]'').ConvertToDateTime($_.TimeGenerated)) -Format g)
RecentShutdowns = ($BootHistory | ? { ((Get-Date)-(Get-Date $_)).TotalDays -le 30 }).Count
LastShutdownReason = 'Reason Code: {0}, Reason: {1}' -f ($_.InsertionStrings[3], $_.InsertionStrings[2])
} | Select $BootInformation
} Catch [System.Exception] {
# We explicitly ignore exceptions originating from Get-Date since some versions of Windows may store dates in invalid formats in the event log after an unexpected shutdown.
If ($_.CategoryInfo.Activity -ne 'Get-Date') {
Write-Warning ("Unable to retrieve boot history for {0}. `nError Details: {1}" -f ($Computer, $_))
# Reset credential object since we may have temporarily overwrote it to deal with local connections.
$Params.Credential = $Original_Credential
$rHistory = Get-RebootHistory
Write-Output "Reboot History:"
$rHistory
Write-Output ""
Write-Output "Boot History"
$rHistory.BootHistory
Write-Output ""
Write-Output "Boot Diagnostics:"
$wDiag = Get-Winevent -MaxEvents ($rHistory.BootHistory.count) -FilterHashtable @{
LogName='Microsoft-Windows-Diagnostics-Performance/Operational'
ID=100}
foreach ($event in $wDiag)
Write-Output "$($event.TimeCreated) | $($event.Message)"
#endregion
