Best method to force server reboots every month at end of maintenance window?
  • December 6, 2021
  • 4 replies
  • 398 views
jbh
We have >1K servers that are distributed among ~50 different groups and policies that patch according to specific maintenance windows based on the application they run.
Our policies allow the server to reboot if the patch being applied requires it, but I’d like ALL the servers to reboot at the end of the monthly maintenance window regardless of installing any patches.
What’s the recommended way to implement this?
jbh
  • December 8, 2021
Nothing?
  • December 10, 2021
You could copy this worklet for rebooting: Worklet Details: Targeted Reboot within Timeframe
Or write your own worklet with “Restart-Computer -Force” and use the scheduler to reboot on your selected schedule
  • December 10, 2021
I went through this recently with another client and decided the best (most simple approach) is either putting Exit 1 in the Eval, and scheduling the policy to reboot with ‘Restart-computer -Force’ as ‘it_stuck’ has suggested, or by putting ‘exit 0’ in the Remediation code and just using the reboot computer feature below the schedule.
jbh
  • December 16, 2021
Thank you both for the suggestions.  I will take a look at them and do some testing.  Wasn’t sure if there was an “official” or generally accepted ‘best practice’ way to accomplish it.
