Hello @Marshyp ,
Regarding your questions about customizing the Automox Tray:
- Company Branding (Logo and "Automox" text): Unfortunately, co-branding, such as displaying your company logo or altering the "Automox" text, is not currently a supported feature.
- Custom Notification Text: The Automox Tray does not currently support custom notification text from IT administrators. Therefore, any custom messaging configured in existing policies will not appear in the tray notifications.
- Deferral vs. Deadline: The Automox Tray operates on a deadline-based system. The "deferral" settings are used to calculate the final install or restart deadline, but they are not visible to users in the tray. Therefore, the settings "Enable Automatic Deferrals" and "Notification Duration" can be ignored within the context of the tray notifications, as they do not affect the user facing notifications. The tray will only display the deadline based information.
I hope this clarifies things. If you have any further questions, please don’t hesitate to ask! You can also read more about configuring policies and understanding tray behavior in our end-user notifications doc and the Automox Tray FAQ.
Thanks @AX-YazMoreno
Do you know if Company Branding and Custom notification text is something that is on the roadmap at all please? I might be making it up, but I’m sure I heard mention of both somewhere!
Thanks for your reply though, that definitely clears things up. Thanks!
@Marshyp,
Great news! It is on the Roadmap.
- Yaz
@Marshyp,
- Yaz
Tremendous! Thanks so much Yaz, this is great.
Really excited for this and a few other pieces on the road map, keep up the great work :)
