Week in Review - Release Notes for Week Ending 9/25/2020
  • September 25, 2020
  • 4 replies
  • 107 views
https://support.automox.com/help/week-in-review-release-notes-for-week-ending-09252020
Enhancements:
  • For CrowdStrike linked accounts: Addressed issues where the trial status was occasionally out-of-sync between CrowdStrike and Automox. (9/23)
  • Misc. query optimizations and performance enhancements.
Bug Fixes:
  • Improved SAML Setup using Identity Provider (IDP) XML Metadata and addressed issues with Azure IDP XML content. (9/23)
Westyy
  • Pro
  • September 30, 2020
Hey guys,
Quick question about the agent whitelisting rules. Has there been any changes to the IP addresses in the last week or so? Do we have a full list?
I know this is posted in the Release notes post but figured if these have updated; its kind of important haha!
https://support.automox.com/help/agent-firewall-whitelisting-rules
Addresses: 44.226.47.242
34.208.84.19
52.35.94.46
54.185.54.196
35.160.81.82
34.216.179.64
54.149.234.23
52.24.155.163
Thanks in advance,
Westyy
As far as I know they haven’t changed. Are you running into any issues that make you think that something is being blocked?
Westyy
  • Pro
  • October 1, 2020
Thanks Nic!
Yeah after checking the firewalls; we did see a few deny’s here and there hence we thought we might bring it up. The list in the link is different to what a typical nslookup against api.automox.com returns. We have seen different IPs more recently.
  • October 2, 2020
If you do an nslookup on api.automox.com that should give you the current up-to-date list.
