Worklet for making HKEY_LOCAL_MACHINE registry changes
  • May 2, 2022
  • 6 replies
  • 902 views
I see there's a worklet in the catalog for making changes to HKEY_USERS. Safe to assume this can be modified to make changes to HKEY_LOCAL_MACHINE ?
  • May 3, 2022
Hey @SomeITGuy - Yes! And there is an example of enforcing changes to HKLM in our KB for your reference: https://support.automox.com/help/enforce-windows-registry-settings-worklet
  • May 4, 2022
Ok, Looking to make quick on/off changes for DCOM testing in anticipation for June.
  • April 27, 2026
This link does not work, do you have a new link to try?  I need to do a couple reg add commands to fix cve-2022-0001
ASkrodzki-Automox
Hey there,
Thanks for flagging the broken link — that KB article was retired when we moved worklets into the Worklet Catalog inside the console. Apologies for the dead end!
IFor what you're trying to do (CVE-2022-0001 / Spectre v2 BHI mitigation on Intel CPUs), here's the path forward:
Starting Point
The Windows - System Preferences - Modify HKEY_USERS worklet in the Worklet Catalog is a solid template. Though, you'll just need to adjust it to target HKLM instead of HKEY_USERS for these registry keys.
Registry Changes for CVE-2022-0001
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v FeatureSettingsOverride /t REG_DWORD /d 0x00800000 /f
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v FeatureSettingsOverrideMask /t REG_DWORD /d 0x00000003 /f
Reference Material
Tip 💡
This is also a great use case for Otto AI — you can have it refactor the HKEY_USERS template to HKLM and wire in the two registry values above in seconds, rather than editing by hand.
Let us know if you'd like a hand validating the evaluation code once you've built it out!
Best regards,
Angelo
  • May 19, 2026
Hi,
We have a few templates in the catalog already setup for 32- or 64-bit registry modifications in HKLM specifically:
https://console.automox.com/manage/worklet-catalog/f1257fae-c0ad-59f8-967d-d279647fc44b
AI is always help to get this put together quick.
Regards,
Mark
ASkrodzki-Automox
Good call Mark!
Best regards,
Angelo
