Run Worklet outside NT AUTHORITY/SYSTEM Context
  • November 5, 2021
  • 2 replies
  • 340 views
Hey folks,
I’ve been working a worklet to enroll Windows 10 device in Autopilot using Graph API.
Mandatory “it works when run manually” but when testing in NTAUTHORITY/SYSTEM context via psexec, it fails. Specifically, when trying to install modules due to network access being heavily restricted in this account.
I could temporarily create a local administrator account, but I’m unsure as to how to run Automox-deployed worklets in another local user context.
Any pointers on how to run Worklets in another (local) user’s context?
Thanks!
  • November 9, 2021
Can’t add much to actually answer the question, but did want to reply as I am also running into this issue. Scripts run fine in PS on my laptop, but when I run them through Automox I get no such luck.
jack.smith
Forum|alt.badge.img+1
  • All Star
  • December 10, 2021
Use the worklet to create a scheduled task that runs in user context.
copy-item script.ps1 C:\windows\temp\script.ps1
$TaskStartTime = (Get-Date)
$SchedService.Connect()
$Task.RegistrationInfo.Description = 'Description'
$Task.Settings.Enabled = $TaskSchd
$trigger.Enabled = $true
$action.Path = "c:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe"
$action.Arguments = '-NoProfile -NoLogo -NonInteractive -ExecutionPolicy Bypass -File "C:\windows\temp\script.ps1"'
$taskFolder.RegisterTaskDefinition("Task Name", $Task , 6, 'Users', $null, 4) | out-null
