Powershell execution policy issue
  • May 16, 2022
  • 607 views
sparrowhawk
Following a vulnerability test recommendation, I enabled the Powershell execution policy on a Windows 2012 server that had had Automox running fine for ages. Now Automox can no longer communicate with the server and it seems this is because the Powershell scripts it tries to run are being stopped by the execution policy. So I disabled the execution policy but this hasn’t resolved the issue. running a Get-ExecutionPolicy - List command shows that at the machine level, the policy is still set to require signed scripts. However, in the local group policy editor and in the registry, the policy has been disabled.
I need to find a way to set the execution policy to run all local and signed remote scripts, so that I can have Automox running but still secure the server.
Any help will be most welcome! Thanks.
sparrowhawk
  • May 16, 2022
I forgot to add that I tried running
 Set-ExecutionPolicy -ExecutionPolicy RemoteSigned -Scope MachinePolicy
And got a warning that policies at the machine level must be controlled by Group Policy, which on the local machine it is. The machine is bound to a domain and there is a default GP in place, but this doesn’t prescribe a Powershell execution policy.
jack.smith
Forum|alt.badge.img+1
  • All Star
  • May 17, 2022
There is something about execution policy I'm not totally grasping but may be related to your situation. In an effort to better understand what’s happening I did some testing to see if I could make heads or tails of this. So far I'm still churning...
For the test I’m using three vantage points
  1. User who is an Administrator
  2. User
  3. NT Authority\SYSTEM
First was to list out the current state of the execution policy. Then I updated the execution policy using the “NT Authority\SYSTEM” account. After the update I reviewed the current configuration for each policy in the currently opened window. Next I opened a new instance and checked the configuration again.
Here are the results.
What I think should be tested next is to implement the configuration through Group Policy and see how that influences each account.
sparrowhawk
  • May 17, 2022
Hi Jack, I’ve been in training workshops all day so will give this some proper thought tomorrow, but you might be on the right track.
