How to query endpoints for GPO or their registry settings and build a list
  • June 22, 2022
  • 279 views
Hello,
We are looking to query endpoints to see if they have certain GPO’s applied and want to build a list of who has or doesn't have the two GPO’s.
The evaluation code in the below worklet looks like it can identify the GPO’s by the registry setting.
https://support.automox.com/help/enforce-windows-registry-settings-worklet
 Any idea’s or help in accomplishing the remainder of our use-case would be appreciated.
JohnG-Automox
  • July 5, 2022
Hello!
You can wrap the gpresult /r /scope:computer command into a Worklet’s remediation code to achieve this.
In your worklet, set the Evaluation code to an Exit 1 so that it immediately triggers the Remediation code:
Exit 1
In the Remediation code, use the following code:
$cmdCommand = 'C:\Windows\System32\gpresult.exe'
$Call = (& $cmdCommand '/r' '/scope:computer')
Write-Output $Call
This will invoke gpresult.exe with the /r and /scope:computer switches and output the results to the Log Summary of Automox Activity Log.
Optional: You can export the Activity Log results to a CSV and filter through to see which devices have inherited which GPOs.
Have a great day!
