Automox Agent is not compatiable
  • November 1, 2022
  • 6 replies
  • 536 views
Hello,
I had installed the Automox Agent on some of our Windows Server vms but it shoes Not Compatiable. Any thoughts on this?
gareth.blakecoggins
Have you checked things like free disk space 3GB or more ?
  • November 1, 2022
Hello @gareth.blakecoggins,
I have checked on all the vms and they have sufficient disk spaces.
  • November 1, 2022
I think I found the issue, maybe it is our network something is blocking it. It shows Server Unreachable.
gareth.blakecoggins
My next suggestion after confirming hard drive space is / was network connectivity
  • November 3, 2022
Drill into one of them and click the following. it should tell you why it is not compatible
BrandonG-Automox
Hello,
If you are unable to determine the reason for the devices showing as incompatible by using the Compatibility Checklist, then please open a support ticket through our Customer Portal so an engineer can assist.
Cheers,
Brandon
