Vulnerability platform integration
  • August 13, 2024
  • 343 views
sparrowhawk
Hi Automox community, I’m investigating ways in which we might improve our patching and remediation. We currently have Tenable VM, which is ok but doesn’t easily integrate with Automox in my experience as I have to import/export csv files. My cloud team are trying out Datadog, which they are really keen on, but does anyone here use it and have you been able to integrate it with Automox?
I know Lansweeper and Rapid 7 integrate with Automox, but they aren’t on my cloud teams radar at the moment. Does anyone use either of these solutions? How do you find them?
If we can’t find a product that easily integrates with Automox, then maybe we can build something. We’d like some way to extract the vulnerabilities from whatever scanning solution we have, stick that data in a database so we can exclude things, then use the Automox API to target devices that require that particular patch. Has anyone here build anything like this?
Forum|alt.badge.img+1
Hi sparrowhawk,
Great question! We have seen several customers utilize the API to push/pull data.
Checkout the Lansweeper Worklets - even though you’re not using Lansweeper, they should serve as a good base for how to automate the uploading of CSV files within the console.
https://console.automox.com/manage/worklet-catalog/95b66900-56e6-58c2-8bc9-de6cc0e1c920
And
https://console.automox.com/manage/worklet-catalog/0d5d60fe-8529-5225-a1a7-40b111fdac32
-Landon
