Upgrading Office clients from 32bit to 64bit
Has anyone put together a working approach for doing this via Automox? I’ve got Windows 10 machines deployed with Office 365 Pro Plus in 32-bit, and I would like to move that to 64-bit.
I understand the general approach is to uninstall all traces of Office 32-bit and then reinstall Office 64-bit. I also know you cannot mix Office 64-bit with Visio/Project 32bit (and Visio / Project are not in the suite of apps for Office). So I’m willing to ignore those machines and handle them manually.
I’ve also done some research into this https://psappdeploytoolkit.com/ that looks like it will do the trick. However, I have concerns about having this running in the user-context so that UI prompts are interactive.
Basically I’m looking to save a ton of work if someone has already built an approach for doing this.
  • May 15, 2020
I haven’t heard of anyone doing that yet, but I’ll ask around.
The worklets run as System, but we do have a code workaround so that you can execute scripts as the current user, if need be. I use that trick in this worklet: Worklet: open website on end user's computer
Looks like Microsoft has an uninstaller tool you can run:
You could kick that off via worklet, then run the installer for the 64-bit version, I would think.
AdamW-Automox
I don’t believe there is an upgrade path from a 32-bit arch, to a 64-bit arch. The way I would handle this is create a Worklet that firsts uninstalls the 32-bit app, and then installs the 64-bit one.
  • Power User
  • May 20, 2020
After considering all the risks involved, I’ve decided to do this manually. Too many things can go wrong with this. 🙂
Microsoft solved this with a MigrateArch attribute
  • Power User
  • June 1, 2020
Yeah, I came across that. It’s got a bunch of pre-requisites though and the computers I am managing don’t all meet those requirements.
Thanks!
