Tag removal question
  • June 7, 2024
  • 2 replies
  • 88 views
CallmePH
I don’t think this is a bug per say, but when “removing” a deployment tag from new pc’s the console deleted the tag as a whole! Is there a way to not have this happen?
Also, this isn’t a worklet question, but I can’t post in the platform forum lol!! The category drop down doesn’t list it! =(
  • Community Manager
  • June 10, 2024
This might be something to reach out to our support team about so they can check on it: support@automox.com!
I did fix the other category for you so you should be able to post in there when needed now. Not sure why your permissions were messed up, but apologies!
CallmePH
  • Pro
  • June 10, 2024
Perfect, thank you Sophia! And I just noticed Otto delivered this morning! Can’t wait to build him!
