Post Automox Install fail
  • February 24, 2022
  • 9 replies
  • 1835 views
  • February 25, 2022
Hi, @crosner -- is this happening on any specific OS or various?
  • February 28, 2022
Edited by mods*
  • March 2, 2022
I actually just ran into the same problem.  I just installed the Automox agent on a couple of systems here.  I get the same error window you get, and looking at the log file I notice:
They all seem to fail the post configuration.  There's a 404 error when they reach out to the site https://api.automox.com/install to verify the compatibility/do the health check.  The Trust Root Configuration is successful, they register successfully, the agent recovery options are successfully configured, and the agent service starts successfully.  Plenty of free space on the system. Powershell 5.x is installed on the systems, they are running Windows  10 Pro  21H2 February update.    When I login to the portal, I see no devices in there. Using the .msi installer downloaded from the portal.
Thanks for any help !
Kind regards
Val
  • April 6, 2022
Do you know what all the sties are?  The documentation only lists 2 automox sites and the Microsoft sites, all of which we can get to.  I checked the IPs for api.automox.com and they are all AmazonAWS IPs. Those are all allowed in my firewall.  I think this is an issue with my ISP, as a tracert does not complete to the targeted IP. I’ll contact them with a ticket.
Thanks for your help!
Val
jack.smith
Forum|alt.badge.img+1
  • All Star
  • April 7, 2022
I’ve used this list for firewall allow-listing. https://support.automox.com/help/agent-firewall-allowlisting-rules
Thanks, Jack for that information.  😁
It appears that it could be related to the fact that I have a demo account, not a full account. They are working on changing that.  I had already opened a ticket with the ISP as we do get out but not all the way to the server IP in a tracert, so it could also be something in their router someplace.
Kind regards,
Val Feehan
jack.smith
  • All Star
  • April 7, 2022
With Sysmon installed and a Packet Capture using Wireshark in progress, I ran this command amagent.exe --checkcompat just like in the error message above. Here is what the output looked like --
In this example I’m using sysmon, which I setup using this guide https://github.com/SwiftOnSecurity/sysmon-config, to figure out what IP address is being used with api.automox.com by reviewing the event logs generated by sysmon. That will produce a list of IPs.
  • three-way TCP handshake
  • TLS negotiations
  • Payload
  • Terminating the TCP connection
