OSX catalina updates going to choose drive screen
  • September 10, 2020
  • 7 replies
  • 132 views
Has anyone run into an issue with when Automox installs an OS update in OSX, that after the system reboots with the staged update, it brings the user to a screen where they need to choose a system drive?
This has been happening for me with some of our systems installing the 10.15.6 supplemental updates. If I do the update using the regular OSX update tool, everything works fine. If Automox installs the update, the user sees these screens:
On the first screen, if you click on update, you get the 2nd screen saying an error occurred. If you click on startup disk, you get only 1 choice…the system disk, and then it asks for the users password and the update installs fine. So it seems like its an issue with filevault unlocking the drive after the reboot
any ideas?
I had that happen to me, and we’ve had a bunch of machines here that had the issue too. Apparently it happens specifically with the T2 chipset, since it’s updating the firmware.
Here’s what worked for me. Rather than doing a reboot, run this command:
sudo shutdown -h now
You can push that out via a worklet if you have a lot of devices having the problem.
hrm ok. I have a worklet to manually prompt for deferred reboots outside of normal patching. I might try that in there and exclude the catalina updates from the normal patching policy. Thanks
It’s not like those reboots are going to hurt anything, they just will have the same experience you documented above. For some reason doing a shutdown, waiting, and then booting it up again works where reboots don’t.
felix.goh
  • September 14, 2020
@spetrov
That’s the one we had every now and then. Cause of problem is t2 chip…
Has anyone seen this behavior on the latest 10.15.7 update? There wasn’t a T2 firmware update included, so I’m curious if the problem still occurred. @emjaydee @felix.goh
  • November 17, 2020
I haven’t gotten that prompt again, so at least my mac is doing ok on that front.
felix.goh
  • November 18, 2020
stopped seeing that problem on my end
