Issue with new System Tray
  • April 15, 2025
  • 9 replies
  • 796 views
We are having issues with users that have applications removed like, firefox or chrome, and continuously showing “Your Computer is preparing to install updates” due to a policy to update both Chrome and Firefox, and it fails for those users and never shows that their computer is Up To Date (this is happening for other applications as well but Firefox/Chrome seems to be the most prevalent offenders)  which is causing confusion with the end users and countless unnecessary calls to our helpdesk.
  • April 15, 2025
I am having a similar issue and haven’t opened a ticket yet, but was planning on it today when it happened to me.  We are getting “Your Computer is preparing to install updates” on PCs where there is no policy that would push this.  It is happening on my PC actually and I don’t have any active policies that would give me this notification.
  • Community Manager
  • April 15, 2025
@SteveM ​@abeidson Definitely open a support ticket with our team so we can take a closer look! Please and thank you
  • April 15, 2025
I have opened a ticket with support, but will update here with the resolution.
  • April 15, 2025
For those having this same issue. Support is telling me it is a known issue.
The issue your devices are experiencing was recently identified and is being worked on by our engineering team.
In the interim, you can use the following command on those devices to clear the stuck notifications.
amagent notifications remove --all
  • April 16, 2025
@abeidson thanks for this.  I’ll let you know what comes out of my support ticket as well in case it’s a bit of a different issue.
  • April 16, 2025
@abeidson did you run the command to clear the stuck notifications?  If so, how did you run it?
cpletcher
  • June 12, 2025
Just run it in PowerShell. I just tried it on one of my devices and now it says Up to Date (Even though it is behind on updates since it was stuck saying it was updating.)
  • June 18, 2025
@cpletcher yup I figured out that was the quickest way.  I run a remote shell from SentinelOne and do it that way.  By any chance do you have a worklet to deploy from Automox?  I have a fear that notifications are stuck for users and they are just not saying anything.  I’d like to run it let’s say once a week to clear out anything stuck.
@SteveM were you able to push that command through Automox though!!
