IPconfig /flushdns Worklet Policy running in a constant 5 min loop
  • April 19, 2022
  • 227 views
Hi All,
Is there a way to make a policy Worklet (already setup) for Ipconfig /flushdns run constantly on like a 5 minute loop for 1000 PC’s. It currently looks like this below. I am moving a Home drive Host VM server to Azure Cloud which will have an IP change and we will change DNS record, and want to minimize downtime.
Evaluation Code
Exit 1
Remedial Code
Ipconfig /flushdns
jack.smith
Forum|alt.badge.img+1
Might be easier to update the DNS records TTL to five seconds so clients have to reach out. Then after cut-over re-adjust to something more appropriate.
Dropping this in a worklet would enable a task to flush dns every minute (lowest time interval accepted) for one hour.
$TaskStartTime = [datetime]::Now.AddSeconds(10)
$SchedService.Connect()
$Task.RegistrationInfo.Description = 'Flush DNS'
$trigger.Repetition.Duration = "PT1H" # do this for 1 hour
$trigger.Repetition.Interval = "PT1M" # every 1 minute
$trigger.Enabled = $true
$action.Path = "ipconfig"
$action.Arguments = "/flushdns"
$taskFolder.RegisterTaskDefinition("Flush-DNS", $Task , 6, 'SYSTEM', $null, 4) | out-null
