Enforce Scheduled Reboot on Machines
  • July 31, 2020
  • Pro
  • July 31, 2020
Hi Nic,
  • July 31, 2020
Sounds good - then the above worklets should do what you are needing then!
The above links are no longer active.  Can you please repost with new URLs to the article?
  • March 20, 2025
I need to schedule a force reboot every week, but I would like to have the ability to postpone it or to action it when the policy runs, I see this thread is really old but posting in case some one can help
