Customize SQL Patching
  • April 24, 2024
  • 284 views
I would like to deploy SQL patches (not the latest version) but a N-1 version leveraging ‘Patch Only’ policy or We need to leverage our script to install a specific package.
jack.smith
Forum|alt.badge.img+1
  • All Star
  • April 24, 2024
Hi @Selvamuthukumaran AS
I’ve found a couple of resources online.
Because SQL Server 2022 wasn’t in mnadobnik function, I’ve extracted the specific module that parsed Brent Ozar’s site and made a few modifications to remove the cache (was throwing errors I did not want to troubleshoot) and add SQL Server 2022 into the list.
Doing all that, here is how to capture N-1 on SQL Server updates
function Get-SqlServerUpdate
.Synopsis
Returns available update list for SQl Server
.DESCRIPTION
Returns available updates list (cumulatvie update, service pack) for SQL Server. Source for updates list - http://sqlserverupdates.com/
Additional information.
When I wrote this script I had a problem with Exception 0x800A01B6,
some tips for me were at this site: https://www.sepago.com/blog/2016/05/03/powershell-exception-0x800a01b6-while-using-getelementsbytagname-getelementsbyname.
In the script I use IHTMLDocument3_getElementsByTagName instead of method getElementsByTagName.
I recommend to use the script at client stations, but I encourage to make a test at servers alternatively. Please send me information about errors and problems by email mnadobnik+blog@gmail.com
.NOTES
Author: Mateusz Nadobnik, mnadobnik.pl
Requires: sysadmin access on SQL Servers
SQLServerUpdates PowerShell module (http://mnadobnik.pl/sqlserverupdates, mnadobnik@gmail.com)
Copyright (C) 2017 Mateusz Nadobnik
.LINK
.EXAMPLE
Get-SQLServerUpdateList
Update list for all SQL Server from version 2008 to 2016
.EXAMPLE
Get-SQLServerUpdateList -Version 2012
Update list only for SQL Server 2012
.LINK
Link: mnadobnik.pl
Date: 09.12.2017
Version: 1.0.1.1
Keywords: SQL Server, Updates, Get
Notes: 1.0.0.4 - Added new object (Link) with links without marks HTML.
1.0.0.5 - Repaired error with TLS 1.2 and added SQL Server 2017
1.0.0.7 - Repaired error Cannot index into a null array.
1.0.1.0 - Repaired error with SQL Server 2017 and refactoring of code.
1.0.1.1 - Repaired error with SQL Server 2008 R2
1.0.1.2 - Bad property outerHTML instead of innerText in the function Get-SQLServerUpdates
1.1.0.2 - Added SqlCredential
1.1.5.4 - Added cache file with list of updates
[CmdletBinding()]
[Alias('Get-SqlServerUpdates')]
[OutputType([string])]
Param
#Version SQL Sever
[ValidateSet('SQL Server 2008',
'SQL Server 2008 R2',
'SQL Server 2012',
'SQL Server 2014',
'SQL Server 2016',
'SQL Server 2017',
'SQL Server 2019',
'SQL Server 2022')]
[string]$Version,
[switch]$Force,
[switch]$Offline
$ElapsedTime = [System.Diagnostics.Stopwatch]::StartNew()
$linkRegex = '"[^"]*"'
$ObjReturn = @()
$parser = New-Object AngleSharp.Html.Parser.HtmlParser
$WebsiteAddress = 'http://sqlserverupdates.com/'
if ((-not (Test-Connection -ComputerName 8.8.8.8 -Count 1 -Quiet)) -and (Test-Path $CachedData))
$ReturnCachedData = $true
elseif ((Get-Item $CachedData -ErrorAction SilentlyContinue | Where-Object LastWriteTime -ge (Get-Date).AddHours(-4)) -and (-not $Force.IsPresent))
elseif ($Force.IsPresent)
$ReturnCachedData = $false
elseif ($Offline.IsPresent)
else
if ($ReturnCachedData)
Write-Verbose "Reading list of updates with cache file..."
$result = Import-Clixml -Path $CachedData
if ($Version)
return ($result | Where-Object Name -eq $Version)
else
return $result
else
try
# enable TLS 1.2
[Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls12
$html = Invoke-WebRequest -Uri $WebsiteAddress
$content = $parser.ParseDocument($html);
Write-Verbose ("{0};Invoke-WebRequest" -f $ElapsedTime.Elapsed)
catch
Write-Output "Check connection..."
if (Test-Path -Path $CachedData)
Write-Output "The module will working on cached data"
Write-Warning $_.Exception.Message
Break
# setting for count of column in table on website
$ColumnSetting = [ordered]@{
'SQL Server 2008' = 4
'SQL Server 2008 R2' = 4
'SQL Server 2012' = 5
'SQL Server 2014' = 5
'SQL Server 2016' = 5
'SQL Server 2017' = 4
'SQL Server 2019' = 3
'SQL Server 2022' = 3
$VersionSQL = [ordered]@{
'SQL Server 2008' = ($content.Links | Where-Object Href -Match "sql-server-2008-updates*")[0]
'SQL Server 2008 R2' = ($content.Links | Where-Object Href -Match "sql-server-2008-r2-updates")[0]
'SQL Server 2012' = ($content.Links | Where-Object Href -Match "sql-server-2012-updates")[0]
'SQL Server 2014' = ($content.Links | Where-Object Href -Match "sql-server-2014-updates")[0]
'SQL Server 2016' = ($content.Links | Where-Object Href -Match "sql-server-2016-updates")[0]
'SQL Server 2017' = ($content.Links | Where-Object Href -Match "sql-server-2017-updates")[0]
'SQL Server 2019' = ($content.Links | Where-Object Href -Match "sql-server-2019-updates")[0]
'SQL Server 2022' = ($content.Links | Where-Object Href -Match "sql-server-2022-updates")[0]
Write-Verbose ("{0};Links" -f $ElapsedTime.Elapsed)
# if set parameter -Version
if ($Version)
$Version = $VersionSQL.$Version
foreach ($SQL in $VersionSQL.Keys)
# $SQL = 'SQL Server 2008'
try
$webHtml = Invoke-WebRequest -Uri $VersionSQL.$SQL.href
$ListUpdates = $parser.ParseDocument($webHtml);
catch
Break
try
$tableUpdateTR = ($ListUpdates).GetElementsByTagName("tr")
$tableUpdateTD = $tableUpdateTR | ForEach-Object { ($_.children) }
catch
Break
for ($i = $ColumnSetting.$SQL; $i -lt $tableUpdateTD.Count; $i++)
# new object
#$update = @{ } | Select-Object
$update = [PSCustomObject]@{
Name = ''
ServicePack = ''
CumulativeUpdate = ''
ReleaseDate = ''
Link = ''
Build = ''
SupportEnds = ''
$update.Name = ($VersionSQL.$SQL.Text).Replace(" Updates", "")
if ($ColumnSetting.$SQL -eq 5)
$update.ServicePack = (($tableUpdateTD[$i].innerHTML) -Replace "( &nbsp;|&nbsp;|^\s)", ""); $i++
$update.CumulativeUpdate = (($tableUpdateTD[$i].innerHTML) -Replace "( &nbsp;|&nbsp;|^\s)", ""); $i++
$ReleaseDate = (($tableUpdateTD[$i].innerHTML) -Replace "( &nbsp;|&nbsp;|^\s|\?\?)", "").Trim(); $i++
if ([datetime]::TryParse($ReleaseDate, [ref](Get-Date)))
$update.ReleaseDate = [datetime]$ReleaseDate
else
$update.ReleaseDate = [datetime]'0001/01/01'
$update.Build = (($tableUpdateTD[$i].innerHTML) -Replace "( &nbsp;|&nbsp;|^\s)", ""); $i++
$update.SupportEnds = (($tableUpdateTD[$i].innerHTML) -Replace "( &nbsp;|&nbsp;|^\s|\?\?)", "").Trim()
elseif ($ColumnSetting.$SQL -eq 4)
$update.ServicePack = ''
else
elseif ($ColumnSetting.$SQL -eq 3)
else
$update.SupportEnds = ''
try
if ([regex]::Matches($update.CumulativeUpdate, $linkRegex) -ne "")
$update.Link = ([regex]::Matches($update.CumulativeUpdate, $linkRegex)[0].Value).Replace('"', '')
elseif ([regex]::Matches($object.ServicePack, $linkRegex) -ne "")
$update.Link = ([regex]::Matches($update.ServicePack, $linkRegex)[0].Value).Replace('"', '')
catch
$update.Link = $null
$ObjReturn += $update
Write-Output $ObjReturn
if ((Get-Item $CachedData -ErrorAction SilentlyContinue | Where-Object LastWriteTime -le (Get-Date).AddHours(-4)) -or (-not (Test-Path $CachedData)) -and (-not $Version))
$ObjReturn | Export-Clixml -Path $CachedData
$ElapsedTime.Stop()
$updates = Get-SqlServerUpdate -Version 'SQL Server 2022'
# return n-1
($updates | Sort-Object ReleaseDate -Descending)[1]
