Built-in support for dynamic group assignment?
  • February 18, 2021
  • 5 replies
  • 479 views
Hi everyone,
Will there be any built-in support for dynamic group assignments coming to the product? For example, MS Azure has built-in features where depending on the OS, the device auto-populates itself in an assigned group upon discovery.
We are a SMB running 90% on MAC, and our IT team is relatively small. They sometimes forget to log on the console and move a device from the default group to our custom groups which have specific patching policies applied to them.
I think this is a feature that would greatly improve qualify of life.
No one likes manual tasks! I think the core principle of the product is a cloud-based hands-off solution. I do read “Auto” in Automox! 🙂
Thank you!
  • Power User
  • February 18, 2021
This feature has been requested, but is not yet available. See https://portal.productboard.com/automox/1-automox-product-portal/tabs/2-under-consideration
You could run a script on a server on your end that would periodically call the Automox APIs to retrieve endpoints (plus their attributes), and based on your criteria, move them to the appropriate groups.
  • February 18, 2021
I know we can create a script and call APIs to do this.
Does every Automox customers run scripts or manually log on the platform for every devices that need switching?
I am curious, how does everyone else handle it?
  • Power User
  • February 18, 2021
I used to do it manually. But I have modified my policies so that everything works on the Default group. Basically, move the logic to the worklet.The worklet decides what to do based on the attributes of the host. Not ideal, but can’t do much until the feature becomes available.
  • February 18, 2021
We are working on this feature currently, but it’s the sort of change that requires a bunch of backend work, so I can’t give you an estimate yet of when that will be available.
In the meantime I do have this script that lets you run RSP and worklets against an list of devices exported from the Device Details page, in case that helps as a workaround:
This script will let you run an arbitrary number of required software policies or worklets against a list of devices exported from the Devices page, in essence giving you a workaround to implement a dynamic group functionality.
Replace YOUR_API_Key…
  • June 29, 2023
Is this feature in AutoMox yet?
It has been 2 years according to the above post.
I would like a dynamic group bases on IP range such as all systems IPs that start with 10.110.0 would go to group 110… I would never have to touch that group again.
Steve
