Automox Communication Exclusion in Crowdstrike Network Containment Policy
  • October 9, 2023
  • 243 views
Hello,
I am seeking assistance to exclude Automox from Crowdstrike Network Containment Policies, allowing the Automox agent to communicate with the cloud even when containment/isolation measures are in lift.
Crowdstrike Falcon presently accepts only IP ranges for Network Containment Policy input due to security concerns related to domain names, as detailed here: Crowdstrike Discussion.
Automox provides a list of URLs used for agent-cloud communication, outlined in this guide: Automox Agent Firewall Allowlisting Rules. I am exploring methods to obtain Automox Cloud's IP range for exclusion. Would it enough to use the IP result from "nslookup api.automox.com"? Please give some advice, many thanks!
Best regards.
  • August 28, 2024
Did you ever get an answer @jake.g ?
