Automox Agent Bulk Deployment Using Kaseya
  • January 17, 2020
  • 7 replies
  • 127 views
Has anyone ever used Kaseya to deploy Automox agents in bulk?
How do you add the access key automatically for all servers/workstations?
  • January 17, 2020
Welcome to the community @Tea-J!
This doc has some bulk deployment scripts you can make use of:
https://docs.automox.com/home/agent-installation/deploying-the-automox-agent-in-bulk
The man thing you need to deploy it with the access key is this syntax:
Automox_Installer-1.0.28.msi ACCESSKEY=your-key-goes-here
You can find your key by clicking on Add Devices from the Devices page.
Rich-Automox
Nic’s right, that’s the easiest way to pass in the access key, assuming Kaseya allows parameters in the cmd line.
The PowerShell script linked in that doc can also accept the access key as a parameter, if Kaseya allows for that.
The method that would cover all bases would be to embed your access key into the MSI file and deploy just the file with no additional parameters. That method is described here:
https://support.automox.com/help/embedding-your-access-key-into-the-automox-msi
  • January 17, 2020
Awesome! Thanks a lot Rich. I think I prefer this option.
  • January 17, 2020
Thanks Nic. I already saw that article earlier but I wasn’t sure how to put in the access key. I guess I wasn’t doing something right. I’m going to use the method Rich suggested. I am more comfortable with that.
  • January 17, 2020
Yeah his method is the simplest, once you embed the access key.
  • January 21, 2020
How is your deployment going? Were you able to get it working ok through Kaseya @Tea-J?
  • January 22, 2020
Hi Nic,
Thanks for checking. I was able to deploy successfully. Thanks for your help. You guys rock!
