2.4.30 Agent Beta
  • September 24, 2025
  • 153 views
Anyone using the beta agent and running into issues? I am seeing a number of failures and the log shows they failed due to execution policy issues. Unable to run the script because running scripts is disabled. This is new.
ASkrodzki-Automox
Review how you are elevating PowerShell execution policy. Avoid running scripts with -unrestricted or running hidden window flags, those may get flagged time to time.
Raise a support request with us to take another look, https://help.automox.com/.
Support request 74340 has been opened. This is on the patching policies, so not script worklets.
ASkrodzki-Automox
Additionally, I would rollback the agent for the time being - if this is a production machine.
Before doing so, support may ask for logs for the device to which you can use this worklet Windows - Forensics - Get Automox Agent Log (amagent.log). Grab that, save/export those logs and submit it to the service request.
Then, to rollback,
  • deregister,
  • uninstall the client,
  • reinstall + reregister the agent
    The following article is a good refresher on the process. Removing the Automox Agent
