Automox Agent Blank Details
  • August 10, 2023
  • 156 views
jack.smith
Forum|alt.badge.img+1
I’m curious if anyone else has run into this and has a solution. The device details page remains blank on 1% of agents ~765 total workstations.
  • Running locally: Get-WmiObject Win32_ComputerSystem shows error “get-wmiobject : Invalid class "Win32_ComputerSystem"
  • winmgmt /verifyrepository shows WMI repository is consistent
  • August 11, 2023
Hey Jack!
Thank you for pointing this out, I’m going to take this back internally and get some feedback on where this problem may be coming from.
You may be hearing from a member of our customer support team and/or our agent team to get more details.
My take is those endpoints may have a corrupt repository
I suggest using these commands in a worklet to kick-start the WMI service by rebuilding the repository.
Which may allow the automox agent to re-populate the data correctly.
net stop winmgmt
winmgmt /salvagerepository
net start winmgmt
jack.smith
  • All Star
  • August 11, 2023
Tried those steps remotely and wasn’t able to get it to work. Might have to see about remote control so I can run the commands locally and give that a go. Thanks for the suggestion!
jack.smith
  • All Star
  • October 13, 2023
Follow-up. The strategy when this happens includes backing up WMI and rebuilding WMI with a batch script, then restoring from a backup. Each use case was slightly different and this was done manually on each device. In some cases, the WMI backup steps were skipped completely. In other cases backing up the MOFs and restoring those kept some unique applications working as intended.
Here is the WMI.bat script
@echo on
if not exist "c:\temp" md "c:\temp"
cd /d c:\temp
if not exist %windir%\system32\wbem goto TryInstall
cd /d %windir%\system32\wbem
net stop winmgmt /y
winmgmt /kill
if exist Rep_bak rd Rep_bak /s /q
rename Repository Rep_bak
for %%i in (*.dll) do RegSvr32 -s %%i
for %%i in (*.exe) do call :FixSrv %%i
for %%i in (*.mof,*.mfl) do Mofcomp %%i
net start winmgmt
goto End
:FixSrv
if /I (%1) == (wbemcntl.exe) goto SkipSrv
if /I (%1) == (wbemtest.exe) goto SkipSrv
if /I (%1) == (mofcomp.exe) goto SkipSrv
if /I (%1) == (WMIC.exe) goto SKipSrv
if /I (%1) == (WinMgmt.exe) goto SKipSrv
%1 /Regserver
:SkipSrv
goto End
:TryInstall
if not exist wmicore.exe goto End
wmicore /s
net start winmgmt
:End
Automox Support, @Bryan.York, helped with a solid process to backup WMI and any MOF exports necessary to ensure a smooth transition.
Backup WMI Repository:
  1. Open an elevated PowerShell window. (Run as Administrator)
  2. Run wbemtest.
  3. Click "Connect," enter root in the "Namespace" field, and click "Connect" again.
  4. Click "Backup/Restore."
  5. In the "Repository backup" section, click "Backup" and specify a backup location.
  6. This action creates a backup of the WMI repository, including MOF class definitions and relationships.
  7. In order to Restore that backup:
  8. In the "Repository backup" section, click "Restore" and browse to the location of your WMI repository backup. Select the backup file and click "Open" to initiate the restoration process.
  9. Follow the prompts to complete the restoration.
Export MOF Definitions:
  2. Run the command: mofcomp C:\Path\To\Your\MOF\File.mof (changing the filepath and name to something of your choosing) to compile and register MOF definitions with WMI.
  3. In order to Import those definitions
  4. You should be able to simply re-run the previous mofcomp command. When you run that command with a filepath to a MOF file that is not present it will create one, when you run the command and there is already a MOF file at that location, it should import it rather than overwrite it.
By following these steps, you should be able to safeguard your WMI configurations and MOF definitions, reducing the risk of application disruptions and enabling a swift recovery in case of issues. I do not, however, know if this would carry over those corruptions after the rebuild so the method would need to be tested as well. Do let me know if that process works.
