I just had my first proper go at adapting some stock worklet code to install some different software and noticed that testing evaluation code in Automox isnt terribly practical. According to the docs “Manual Execution… triggers the remediation script regardless of the compliance status of the device.” So when using manual execution (which is the easiest way to test new worklets) the evaluation code is completely ignored.
I think the solution I would like to see would be a manual execution “Debug” mode that you could run to test both evaluation and remediation code, and would preferably also return the full output from both scripts (feedback from the scripts themselves seems a bit thin atm, so it would be nice if the activity log or something was more verbose). Am I just doing things wrong atm or is this actually a worthwhile suggestion? How does everyone else go about testing their scripts before running them in production?
