Tag removal question
  • 7 June 2024
  • 2 replies
  • 31 views
I don’t think this is a bug per say, but when “removing” a deployment tag from new pc’s the console deleted the tag as a whole! Is there a way to not have this happen?
Also, this isn’t a worklet question, but I can’t post in the platform forum lol!! The category drop down doesn’t list it! =(
This might be something to reach out to our support team about so they can check on it: support@automox.com!
I did fix the other category for you so you should be able to post in there when needed now. Not sure why your permissions were messed up, but apologies!
Perfect, thank you Sophia! And I just noticed Otto delivered this morning! Can’t wait to build him!
