Having some errors pop up on a handful of pc’s when using the Patch Now Action on the Software page. Have a handful needing 23H2, and while some took the update with 0 issues some are throwing the following
No override file found. Patch default values will be used
Failed to set patch values from Metadata. Default values will be used.
InstallMSUpdates : Install failed with ResultCode 4 and HResult -2145124318
At C:\Program Files (x86)\Automox\execDir149571395\execcmd013954502.ps1:1788 char:21
+ InstallMSUpdates $lst
+ CategoryInfo : NotSpecified: (:) :Write-Error], WriteErrorException
+ FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,InstallMSUpdates
Any ideas on way some will update while others have this error?
