Good Afternoon,
I’m planning on deploying via GPO using MSI.  I’ve gotten the ACCESSKEY entry added to the MSI using Orca.  I was hoping to assign device group membership as well.  Could someone please provide the syntax for this?  I haven’t had any luck, and am not finding any documentation.  I tried the following with no success:
Property: GROUP
Value: “Default/Parent Group/Device Group”
Thanks!
Hi csmith6,
i’ve got a screenshot for you:
That’s very helpful, thanks!
My problem(s) was:
a) I was using ‘Default’ instead of ‘Default Group’
and/or
b) I had put the value in quotes.
It seems to be working now, thanks for your quick and helpful response!!!
