We have PCs dotted around the world, although most are in the UK. All of them at some time or another can be a struggle to connect to with automox.
I found with a couple recently, I had to use team viewer to connect and remove VNC - because the port was engaged by VNC, it was seen as ‘busy’ when attempting to connect. So you could never connect.
After removal, Automox would then re-connect, re-install VNC and all would be well.
I could write a worklet to remove VNC I guess, but was wondering how easy it would be just to use a worklet to free up the port?
Hi @JST !
We do have a Worklet in our Catalog for uninstalling TightVNC:
Windows - Software - Uninstall TightVNC
If you are looking to create a worklet that just disconnects the agent, it appears that you could do this programmatically using the -disconnectall switch issued via command line.
Source: https://www.tightvnc.com/doc/win/TightVNC_2.7_for_Windows_Server_Command-Line_Options.pdf
Hope this helps!
