We have PCs dotted around the world, although most are in the UK. All of them at some time or another can be a struggle to connect to with automox.
I found with a couple recently, I had to use team viewer to connect and remove VNC - because the port was engaged by VNC, it was seen as ‘busy’ when attempting to connect. So you could never connect.
After removal, Automox would then re-connect, re-install VNC and all would be well.
I could write a worklet to remove VNC I guess, but was wondering how easy it would be just to use a worklet to free up the port?
