Working in a script able to delete files in privileged folder like system 32.
But getting “File '\Windows\System32\Tryme\new 2.txt' does not exist.” on the script bellow.
According to the reponce on  this:
Automox runs as SYSTEM so this issue is unlikely related to elevated privileges.
Any suggestions? What am I missing here?
Evaluation Code:
Exit 1
Remediation code:
$filePath = "C:\Windows\System32\Tryme\new 2.txt"
# Check if the file exists
if (Test-Path $filePath) {
    try {
        # Attempt to delete the file
        Remove-Item -Path $filePath -Force -Recurse
        Write-Output "File '$filePath' has been successfully deleted."
    } catch {
        # If an error occurs, display the error message
        Write-Output "An error occurred while trying to delete the file: $_"
} else {
    # If the file does not exist, inform the user
    Write-Output "File '$filePath' does not exist."
Hi @victor.tremea !
I believe the issue you are seeing is related to the fact that the Automox agent is a 32-bit process.
You'd want to use sysnative to return the redirected SysWoW64 folder and test for the file in there.
Source: https://learn.microsoft.com/en-us/windows/win32/winprog64/file-system-redirector
Example, $filePath = "$env:windir\Sysnative\Tryme\new 2.txt"
Let me know if that doesn’t work for you!
That worked! Thank you, @JohnG-Automox .
