Automox confusing host names/fqdn
  • November 22, 2023
  • 268 views
I am onboarding my devices having come from another product. I am having issues correctly onboarding my 4 DNS servers (ubuntu) and my webserver (ubuntu)
I onboarded my webserver first, it registered and initially displayed the correct info in the System Details. I proceeded to onboard DNS01 and I received the Slack message it hit my account. When I went to device details DNS01 is not in the list and my webserver is now displaying the DNS01 fqdm in system details.
Any ideas to either correct this within the GUI or manually edit the details on the endpoint?
  • 141 replies
  • November 22, 2023
Hi CNYMetalGuy,
We often see this behavior if the machines have been cloned and the agent doesn’t have enough differentiating information to create a separate object for each device. This results in a single entry being used essentially by each device whenever they scan, resulting in the information of a single object changing (hostnames/IP information/hardware details). Some more detail here if that is the case:
https://help.automox.com/hc/en-us/articles/6212735367060-Linux-Devices-Share-a-UUID
  • November 25, 2023
To update, I’ve experienced this issue with a few of my linux servers. And still ongoing. I’ve tried the following:
Uninstall/reinstall amagent
Unregister and reregister
Stop service, delete and reset the UUID, and restart the service
Most of the time these steps fail to resolve the issue. They will not even show up in the devices. I do have several similarly built servers. Same specs but named different. This has only been an issue with my linux boxes (ubuntu and RHEL). Not an issue with any Win servers
philips66
  • 4 replies
  • December 11, 2023
We experienced the same issue, the root cause was duplicate machine-id for our linux systems (because we use vm templates) and the fix in the article that Mark links to worked to resolve the issue for us
