Hey all,
^ +1 to this!
Hopefully we get a reply 🙂
Hi OP and commenters, we have seen some success with the following worklet:
+1 On This!
Any update on Automox adding the Feature to update Drivers on Windows Devices through the Patch Policies? Since the number of updates seen on a device when you enable optional updates is not more than 5 or less. But the device is actually missing more than 5 Driver updates. Using the vendors apps to do this is becoming a bit of hassle as those apps are becoming bloatware on endpoints and have more vulnerability of being exploited. We wanted to use Windows Update Agent’s Driver Update Catalog, as this is a common application, we can rely on, regardless of the different make and manufacturer for the device. So, it’ll be greatly appreciated if Automox Dev can look into integrating Driver Updates using the Patch Policies. Being MSPs, we have different kind of customers, who use different brands of hardware. We cannot force them to use one brand. We try to where-ever we can, but it's not always the provider’s call. We have to be flexible to accommodate all kind of windows devices.
